EB500 bluetooth module
I'm using BS2sx, with intended baudrate of 9600, 8 data bit, no parity bit and stop bit =1
with the EB500 bluetooth module.
is the following code correct to set it visible?
SEROUT 1,240,[noparse][[/noparse]"set visible",CR]
DEBUG "setting visible...",CR
SERIN 0,240,[noparse][[/noparse]WAIT("ACK",CR)]
SEROUT 1,240,[noparse][[/noparse]"on",CR]
DEBUG "visible set",CR
ex:· SERIN 0,84,[noparse][[/noparse]WAIT("ACK",CR)]· before performing any other function.
The SET VISIBLE requires iether· "ON or OFF" as per the documentation but I could not get the command to work. I obviousley get and acknowledgement from the "SET VISIBLE OFF" command, otherwise it would still be waiting for the ACK and not continue.
' {$STAMP BS2}
' {$PBASIC 2.5}
'Get Visible status
answer1 var byte(3)··· ' 3 byte array for "O,F,F"· or· "O,N, "
answer2· var byte(3)
PAUSE 1000·· 'Wait for the eb500 radio to be ready
'Connect to the remote device
DEBUG "Connecting to 00:03:7A:2C:7C:B1",CR· 'laptop
SEROUT 1,84,[noparse][[/noparse]"con 00:03:7A:2C:7C:B1",CR]··· 'issue command
SERIN 0,84,[noparse][[/noparse]WAIT("ACK",CR)]··· 'wait for acceptance of command
DEBUG "Connected· to device: 00:03:7A:2C:7C:B1",cr
'Get Visible status
SEROUT 1,84,[noparse][[/noparse]"get visible",CR]·· 'issue command
SERIN 0,84,[noparse][[/noparse]WAIT("ACK",CR)]·· 'wait for acceptance of command
SERIN 0,84,[noparse][[/noparse]str answer1\3]······ ' I want a STRing of 3 bytes
DEBUG "Visibility is: ",STR answer1\3,CR·· 'display a STRing of 3 bytes
'set invisible
SEROUT 1,84,[noparse][[/noparse]"set visible off",CR]
debug "Can you see me now?",cr
pause 2000
'Get Visible status
SERIN 0,84,[noparse][[/noparse]str answer2\3]······ ' I want a STRing of 3 bytes
DEBUG "Visibility is: ",STR answer2\3,CR·· 'display a STRing of 3 bytes
Furf
