Help on implementing servo positioning with HB25
Hello to all.
I have hard time coding·feedback control·from my motor that is driven by a HB25. What I currently do is to have the BS2 send a position pulse to HB25 and read the angle of the shaft of the motor with a pot aligned to it with the help of a ADC0831. The problem is that the motor keeps rotating before the feedback can correct the angle of the shaft by reducing its speed or stops it when the right angle reached. It overshoots and its osclillating. I gets even more bad when it has to react on faster transitions of angles. When I tried to set a debug print to monitor what happens, the extra delay almost destroyed the potentiometer by tearing it off from the motor shaft!
I intend to use two HB25 controllers doing the·such positioning job in one BS2 and plus some·other fuctions like RS232 data input·and·this behavior·worries me...
Any ideas?
Rgrds Thanos
Greekbotics: Greek Robotics Forum
(Translate it using Babelfish)
Any ideas?
Rgrds Thanos
' {$STAMP BS2}
' {$PBASIC 2.5}
HB25 PIN 13 ' I/O Pin For HB-25
Clk············ PIN···· 1······················ ' ADC0831.7 (both)
Dio············ PIN···· 0······················ ' ADC0831.6 (both)
CS0············ CON···· 2······················ ' ADC0831.1 (ADC 0)
CS1············ CON···· 3······················ ' ADC0831.1 (ADC 1)
[noparse][[/noparse] Variables ]
idx············ VAR···· Nib···················· ' ADC identifier
adc············ VAR···· Byte(2)················ ' raw adc value
shaftpot VAR Byte
userpot VAR Word
servovalue VAR Word
centerpos CON 623
[noparse][[/noparse] Initialization ]
DO : LOOP UNTIL HB25 = 1 ' Wait For HB-25 Power Up
LOW HB25 ' Make I/O Pin Output/Low
PAUSE 5 ' Wait For HB-25 To Initialize
PULSOUT HB25, 750 ' Stop Motor 1
[noparse][[/noparse] Program Code ]
Main:
DO
· idx = 0
· GOSUB Read_0831
· userpot = adc(idx)
· userpot = userpot * 2
· idx = 1
· GOSUB Read_0831
· shaftpot = adc(idx)
· servovalue = centerpos + (userpot - shaftpot)
· PULSOUT HB25, servovalue···· 'set to 0 degrees before FS gaining control.
·· ' DEBUG DEC userpot, " ", DEC shaftpot, " ", DEC servovalue ,CR
LOOP
STOP ' Use STOP To Prevent State Change
[noparse][[/noparse] Subroutines ]
' Reads selected ADC0831
' -- pass unit in 'idx' (0 or 1)
Read_0831:
· LOW (CS0 + idx)
· SHIFTIN Dio, Clk, MSBPOST, [noparse][[/noparse]adc(idx)\9]
· HIGH (CS0 + idx)
· RETURN
Thanos
·· I don’t see how you’ll be able to do this…If you’re using a standard DC Motor it would be inclined to turn continuously whereas it seems like you want standard servo positioning.· DC Motors aren’t set up like that.· If the output shaft is not highly geared you can expect overshoot.· The HB-25 is trying to set the speed of the motor while you’re trying to set the position.· High gear ratio may help, but I don’t think it will solve your problem.· Remember too that the HB-25 requires a single pulse for a given speed.· Your loop monitoring the angle would be faster if not refreshing the HB-25 unnecessarily.· I hope this helps.· Take care.
The only thing that remains now is to·try to make a custom feedback controller to handle the math and just let BS2 output simple servo pulses.
Thanks anyway, Thanos
