Len of file dat — Parallax Forums
Len of file dat
bassmasterbassmaster Posts: 181
edited 2007-01-02 14:56 in Propeller 1
Any easy way to get the length of a binary file in memory when read.
DAT
···myfile file "myfile.bin"···
I can use windows explorer to get the size then hard code it, but that bites.
Sean
    edited 2007-01-01 23:42
    You could try
    DAT
    sizeOf  long  sizeOf - myfile
    I haven't tried it, but it ought to work.
  • Ym2413aYm2413a Posts: 630
    edited 2007-01-02 00:08
    The file formats I made for use with the propeller all have the file size in the header.
    But normally what I do is just right click on a file and read its properties.
    It's pretty fast and only takes a second.
    edited 2007-01-02 00:17
    BassMaster.
    Sizeof is a pointer.
    DAT
    varsize long varsize - myfile
    This would do the same thing.
    I'm not sure if you have to use the @ symbol though with that code since they are pointers.
    DAT
    mysize long @mysize - @myfile
    I haven't tried the above either, But it's a good starting point.
  • bassmasterbassmaster Posts: 181
    edited 2007-01-02 00:21
    Ym, that is ok, as long as the file does not change. I am curious if I could make a program that would take a file regardless of size by the same name, and not add any new code to re-load it.
    edited 2007-01-02 00:27
    mysize long @mysize - @loadme
    works perfectly... thanks...
    Your welcome.
