Balancing Robot Using Ping
My goal is to build a balancing robot that can roam and avoid obstacles. As a first step I built a simpler robot that can balance in place or move slowly forward or backward over a level surface.
I posted a video at
I used mostly components from my last Boe-Bot project: Parallax continuous rotation servos, a BOE development board with a BS2sx chip and Ping to measure tilt angle. The balance point can be moved slightly fore or aft with on-board buttons to choose stationary or slowly moving behavior and to fine tune for different environments. The chassis is made from Radio Shack perf board. For power I’m using five Ni-CDs, whose low internal resistance provides quicker surges as the servos constantly start, stop, and change direction. The only non-Parallax working parts are 3” model airplane wheels.
I chose the Ping as tilt sensor after tests showed it to be the most accurate of the sensors I had on hand from previous projects. I collected data·by running the robot with the serial cable attached, holding the cable to minimize it's affect on balance. Not elegant, but it worked.
The closed feedback loop is based on Andy Lindsay’s wonderfully clear explanation·of how to implement a PID loop on a Basic Stamp. For this application I found that for the integral term, rather than maintaining a running total, ·I got better results with a leaky accumulator which remembers only the previous two errors.
I’m eager to start a more sophisticated balancing robot and·I’d appreciate any ideas or advice:
I’d like to go with a gyro/accelerometer combination. I already have a Memsic 2125. What’s the best choice for gyro? Perhaps the ADXRS300 on a breakout board from SparkFun.com? Does anyone have ideas or leads on information about algorithms to utilize these sensors on a Basic Stamp or SX chip (preferably in SX/B)?
I’d like to use DC motors. Any suggestions on motors that have a little more torque, a little more speed, and a little less latency than hobby servos?·
Thanks!
Below is the latest version of the pBasic code.
/John
' {$STAMP BS2sx}
' {$PBASIC 2.5}
' Balancer.BS2X. A simple two wheel balancing robot using a
' Ping))) sensor for tilt angle.
' John Fisher, January 2007
[noparse][[/noparse] I/O DEFINITIONS ]
· buttonBottom······ PIN···· 10
· buttonTop········· PIN···· 11
· rwheel············ PIN···· 12
· lwheel············ PIN···· 13
· ping·············· PIN···· 14
· speaker··········· PIN···· 15
[noparse][[/noparse] CONSTANTS/PARAMETERS ]
' PID contstnts:
· Kp··········· ·····CON······ 2····
· Ki················ CON······ 2····
· Kd················ CON······ 4····
'Meaningful names for error array index:
· Current··········· CON······ 0
· Sum··············· CON······ 1
· Last·············· CON······ 2
· SecondtoLast·· ····CON······ 3
· Delta············· CON······ 4
[noparse][[/noparse] VARIABLES ]
· pTime············· VAR···· Word··· ' raw value from Ping)))
· drive············· VAR···· Word··· ' value sent to Motors
· error············· VAR···· Word(5)
· p················· VAR···· Word··· ' proportional term
· i················· VAR···· Word··· ' integral term
· d················· VAR···· Word··· ' derivative term
· SetPoint······ ····VAR···· Word···
· counter··········· VAR···· Nib····
[noparse][[/noparse] INITIALIZATION ]
Reset:
GOSUB ProgramStartSound
SetPoint = 540
[noparse][[/noparse]PROGRAM CODE ]
Main:
IF buttonTop = 1 THEN
· SetPoint = SetPoint + 1
· FREQOUT speaker, 12, 1350··· ' confirm button push
· PAUSE 175
ENDIF
IF buttonBottom = 1 THEN
· SetPoint = SetPoint - 1·····
· FREQOUT speaker, 12, 1250··· ' confirm button push
· PAUSE 175
ENDIF
DO
·PULSOUT ping, 12
·PULSIN ping, 1, pTime
·IF (pTime<425)OR(pTime>625)THEN GOTO Main 'Shut down motors
·········································· 'if beyond recoverable
·········································· 'tilt angle.
·error(current) = setPoint - pTime
·p = error * Kp
·error(Sum)=error(Current)+error(Last)+error(SecondtoLast)
·i = Ki * error(Sum)
·error(Delta) = error(Current) - error(Last)
·d = Kd * error(Delta)
·drive =· p + d + i
·GOSUB Motors
·error(SecondtoLast) = error(Last)
·error(Last) = error(Current)
' Code to send runtime data to debug goes here. The
' Parallax oscilloscope was used to check the actual
' time between motor pulses so the pause in the motor routine
' could be adjusted to stay close to 20 ms. The main value
' of using the BS2sx was that the BS2 was not fast enough
' to read the sensor, calculate the motor input, send
' data to debug, and get back to the motors within 20 ms.
LOOP
END
[noparse][[/noparse] SUBROUTINES ]
ProgramStartSound:
· FOR counter = 4 TO 1
··· FREQOUT speaker, 30, (1320) - (counter * 36)
··· PAUSE 100
· NEXT
RETURN
Motors:
· PULSOUT lwheel, (1871 + drive) MIN 1625 MAX 2111
· PULSOUT rWheel, (1875 - drive) MIN 1625 MAX 2125
· PAUSE 3
RETURN
I posted a video at
Thanks!
/John
' {$STAMP BS2sx}
' {$PBASIC 2.5}
' PID contstnts:
Reset:
SetPoint = 540
Main:
· PAUSE 175
ENDIF
· PAUSE 175
ENDIF
DO
·PULSOUT ping, 12
·p = error * Kp
·drive =· p + d + i
·GOSUB Motors
LOOP
END
ProgramStartSound:
··· PAUSE 100
· NEXT
RETURN
Motors:
· PAUSE 3
RETURN
The Ping reading only takes a few milliseconds. If you run them back to back strange things happen - probably the echoes are still bouncing around the walls. But there's no reason to update the readings faster than the 20 msecond servo pause, and at this rate everything works fine.
/John
Have you tried yet to move it around?
Look on my simular project for code ideas to add to it a simple 4 channel RF control:
http://forums.parallax.com/showthread.php?p=570699
Regards, Thanos
Greekbotics: Greek Robotics Forum
(Translate it using Babelfish)
Impressive! .... what happens if you jingle your keys nearby?
Beau Schwabe
IC Layout Engineer
I have read over both yours and Tronics, you both have done good work.
Beau, I haven't tried jingling keys, but the Ping is definitely sensitive to ambient noise that gets into the ultrasonic range, maybe from harmonics. Forget Kalman filtiers - we need jingle filters for the Ping!
/John
-Rule your Destiny-
--Be Good. Be Bad. Be Provas--
The hellinic (Greek) robots portal: Greekbotics
Many Projects and Schematics by the users·and also robotic news
(Translate using babelfish)
I included my dirty dirty code if anyones interested. Some math in the code does not really make sense. I think im getting errors due to current fluctuations but not sure. I need to go thru it when im not tired and really debug it.
And here is the video on you tube.
http://www.youtube.com/watch?v=9ZdlpufdbfI
Think of an inverted pendulum. Or try this -- balance a shop broom by the handle (with one finger). Easy. You can move your arm quite a bit and the broom head hardly moves. Now try it with the handle in the air. Almost impossible. Or think of a unicyclist -- the rider can peddle the wheel back and forth over nearly two feet and his/her upper body may hardly move at all (relative to the ground).
Way cool 'bot. Post more video when you have it turning and such!!!
Larger wheels definitely help the bot to balance, but I'm not sure why. Maybe it's just that the larger wheels give the small servos more speed along the ground. Seems like more than that, but I don't know what.
Another question I can't get my arms around is this: when the motor makes the drive shaft and wheels turn, how does that effect the rest of the robot? I can't figure out whether a wheel turning clockwise generates a clockwise or counterclockwise force to the chassis. And are the two wheels generating the same force to the chassis, or opposite forces? In each configuration of my bot I found an unexpected turning tendency. Maybe this is because of the opposite rotation of the two wheels.
Sure wish I had paid more attention when I took physics in college.
/John
I think the fore and aft distribution will work against you unless the weight is brought down near the ground (like an inverted "U" braced across the top of your 'bot with weights at the bottom of the descenders). You will also have considerable inertia with that kind of setup (meaning more power & time to effect a result).
The larger wheels help mostly to give you greater speed in a shorter time -- i.e., faster corrections. There will be a inverse trade-off in power, of course. It is also possible that getting the pivot point of your balance a bit higher above the wheel's contact with the ground helps, but like you, my physics suffers at that point.
Your tendency to turn may be slight mismatches in servo speeds -- send the same pulse to both servos and you probably won't get exactly the same speed on either one. You might want to set up manual neutral/max/PID constants for EACH wheel to get them tuned (in the absence of real-world encoders, that is).
Have you seen the Bal-bot site? They have a very tall balancing 'bot with the battery weight way, way up high. Very large wheels, too, relative to the size of the 'bot.
www.balbots.com/product_info.php?cPath=21&products_id=28
I guess they had a fire and are not shipping product anymore, which is too bad.
The higher the center of mass is, the greater the damping effect on the whole system. THis is good because as can be seen in the video the servos are jerking around alot and causeing it to overshoot back and forth. So if I move the batteries higher it will not overshoot so bad and become more stable.
The other trade of is between height and the max speed of the servos. The servos have enough torque to do the job but top speed is an issue. Basicly there is a direct relationship between max motor speed and recoverable tilt angle. If I move the center of mass I restrict the recoveable angle for a given maximum motor speed.
This means the higher the center of mass the more important it is to have a very precise measure of tilt angle to drive the motors with. The way I have the bot set up right now the ping is very close to the center of the body and at an angle. I need to get rid of the angle and have it point straigt down when balanced so that the change in ping time will be equal in either tilt direction. And i need to move it out from the bode a few inches to get the additional precision needed to move the Center of mass uppward effectively.
Also anyone ever heard of the Grand Challenge. I was on the VA Tech Team.
http://www.youtube.com/watch?v=vhJIWGOb8hg
Since the whole thing can be done with Parallax parts, maybe this could be a Boe-Bot/Ping))) AppNote. It's a really fun project and a surprising and impressive accomplishment for this collection of parts.
/John
I like your simplistic approach to the balancing bot problem. Seems to be a very popular project idea. Yours is one of the most vertical ones that I have seen, great job!!
What did you use for the frame, looks like some sort of plastic and hot glue? Is it light?
D Faust
Thanks! I made the frame from Radio Shack perf board, glued up with epoxy. I live in an apartment and my workshop is also the dining room table, and everything gets folded up and stowed in a closet after every·work session,·so I have no choice but to keep everything very simple.·Maybe that's a blessing in disguise.
In the middle of experimenting with various combinations of accelerometers and gyros, I got even more interested in this guitar tuner project: http://forums.parallax.com/showthread.php?p=641934
At the moment I'm getting ready for a trip to Germany and I hope to get back to both the tuner and·the balancing robot project in July.
Looking forward to seeing progress by others with balancing robots, particularly using combinations of prop/accelerometer/gyros.
/John
Very cool. I am amazed how well it works.
Whit+
Whit+
Post Edited (Whit) : 6/6/2007 4:55:08 AM GMT
Future enhancements: I'm going to see if I can squeeze in a logging function to pull data from the PID to demonstrate exactly how it controls the balance point. Tried it real time with my eb500, but no joy due to lag on servos. Thanks to all those who inspired me to experiment.
Somebody give me a problem, cuz I'm itching to experiment...
Video is here:
' BalancingBotUsingpiD.BS2
' {$PORT COM1}
' {$STAMP BS2}
' {$PBASIC 2.5}
[noparse][[/noparse] Constants ]
SetPoint CON 130 ' Set point
Kp CON $03A0 ' proportional constantc
Ki CON $01A0 ' integral constants
Kd CON $0100 ' derivative constants
Current CON 0 ' Array index - current error
Accumulator CON 1 ' Array index - accumulated error
Previous CON 2 ' Array index - previous error
Delta CON 3 ' Array index - change in error
ServoCenter CON 750 ' Servo not moving
IntErrorOffset CON 100
IntErrorMax CON 200
IntErrorMin CON 0
[noparse][[/noparse] Variables ]
pTime VAR Word
error VAR Word(4) ' Four different types of errors
pulseLeft VAR Word ' Output
pulseRight VAR Word
signA VAR Bit
signB VAR Bit
A VAR Word
B VAR Word
counter VAR Byte
p VAR Word
i VAR Word
d VAR Word
[noparse][[/noparse] Pins ]
Ping PIN 14
Left PIN 12
Right PIN 13
log DATA @0
[noparse][[/noparse] Initialization ]
DEBUG CLS
SEROUT 1,84,[noparse][[/noparse]"LABEL,TIME, Dist,P, I, D, Pulsleft, PulseRight",CR]
main:
DEBUG ?ptime
FOR counter = 0 TO 4
error(counter) = 0
NEXT
DO
LOOP UNTIL IN8=1
DO WHILE IN8=1
GOSUB Get_Ping_Distances
IF (ptime = setpoint) THEN GOTO Start
LOOP
[noparse][[/noparse] Main loop ]
start:
IN8=0
FREQOUT 2,2500,2000
DO
'SEROUT 1,84,[noparse][[/noparse]"DATA,TIME,",SDEC ptime,",",SDEC p,",",SDEC i,",",SDEC d,",",SDEC p+i+d,",",SDEC error,CR]
IF (pTime < setPoint - 90) OR (pTime > setPoint + 90) THEN GOTO main
GOSUB Calc_Drive
GOSUB Send_Pulse
'WRITE log+counter, ptime
'counter = counter+1
LOOP
[noparse][[/noparse] Calculate Drive ]
Calc_Drive:
GOSUB ErrorCalc ' Error Calcs
GOSUB PropCalc ' Perform proportional error calcs\
GOSUB IntCalc ' Perform Integral Calcs
GOSUB DerivCalc ' Perform Derivative calcs
RETURN
[noparse][[/noparse] Calculate Error ]
ErrorCalc:
error(Current) = SetPoint - pTime
RETURN
[noparse][[/noparse] Proportional Drive - Sign adjusted ]
PropCalc:
A = error(Current)
B = Kp
GOSUB Fractional_Multiply
pulseLeft = pulseLeft + A
pulseRight= pulseRight - A
'p=A
RETURN
[noparse][[/noparse] Integral Drive - Sign Adjusted ]
IntCalc:
error(Accumulator) = error(Accumulator) + error(Current)
error(Accumulator) = error(Accumulator) + IntErrorOffset MAX IntErrorMax MIN IntErrorMin - IntErrorOffset
A = error(Accumulator)
B = Ki
'i=A
RETURN
[noparse][[/noparse] Derivative Drive ]
DerivCalc:
error(Delta) = error(Current) - error(Previous)
A = error(Delta)
B = Kd
pulseRight = pulseRight - A
error(Previous) = error(Current)
'd=A
RETURN
[noparse][[/noparse] Subroutine - Get_IR_Distances ]
Get_Ping_Distances:
PULSOUT PING, 5
PULSIN PING, 1, pTime
IF pTime = 0 THEN GOTO Get_Ping_Distances
DEBUG HOME, CLS,?ptime
RETURN
[noparse][[/noparse] Subroutine - Send_Pulse ]
Send_Pulse:
PULSOUT Left, 750 + pulseRight MIN 650 MAX 850
PULSOUT Right, 749 + pulseleft MIN 649 MAX 849
pulseLeft = 0
pulseRight = 0
RETURN
[noparse][[/noparse] Subroutine - Fractional_Multiply ]
Fractional_Multiply:
signA = A.BIT15
signB = B.BIT15
A = ABS(A) */ ABS(B)
IF signA ^ signB THEN A = -A
RETURN
I like your Balancing Robot, great job! I have an extra BS2SX and would like to·try·to duplicate your effors. Could you please explain the purpose of the two buttons (ButtonBottom and ButtonTop). I assume that they set some "tilt" points for the PID calculation? How are they used in the balancing setup?
Mikes
I just saw the video
This is a nice design, apparently based on standard parts
Would you let us have more info on your baby, and post some more photos
If you allready did, please direct me to the right direction
Yves
Have you still got the link to Andy's PID post - i remember seeing it but cannot find it on the search.parallax.com
good project!
Cheers,
James
http://forums.parallax.com/showthread.php?p=529609
enjoy
yves
I also want to make BalancingRobot to read this.
I had MX2125, and made motor-driver-curcuit(1 motor).
Operation for MX2125 and motor-drive are OK.
Using mG instead of ping.
mG: 30degree:+500 0degree:0 -30degree:-500
I cannot understand "PULSOUT lwheel, (1871 + drive) MIN 1625 MAX 2111" on Motors SUBROUTINES .
How do these value determine?
And right and left motor need?
Is these someone in the "draft this week"published last week?
