USB stopped working
I fired up my Windows 2000 machine today to spend some quality Spin time and suddenly the Propeller Tool doesn't see the Propeller. I re-ran USBDriverInstallerV2.0.0 and got the message "FTDI CDM Drivers have been successfully installed." I shut down and restarted. When I connect my Propeller demo board, my Propeller Clip, or my Professional Development Board the Found New Hardware Wizard comes up and says "An error occurred during the installation of the device. The installation failed because a function driver was not specified for this device instance."
The blue and red LEDs both flash on the Propeller Clip and Propeller Demo Board when USB is connected.
In Device Manager, the device shows up under Universal Serial Bus controllers as "USB Device" with a yellow exclamation point. It isn't getting installed as a virtual COM port so there is no way to adjust Latency Timer.
I've tried connecting through a powered hub and directly to my computer's USB port.
Connecting to a PropSTICK through a serial port works fine.
The driver worked fine a couple weeks ago. I think the only change since then is that today is the first time I tried to connect the Propeller Clip.
OS-X: because making Unix user-friendly was easier than debugging Windows
links:
My band's website
Our album on the iTunes Music Store
links:
My band's website
When I try to reinstall the driver and let Windows search for a driver, it finds c:\winnt\inf\usb.inf. I tried manually selecting ftdibus.inf and ftdiport.inf but neither one worked.
links:
My band's website
My setup may be a little unique, I have one real serial port, a 4 port edge/4 USB to serial, two modern FTDI USB to serial adapters, and the Parallax USB scope, that installs as a USB serial port. Also several GSM/GPRS devices that are USB serial. The Propeller Tool will only work with the real com port or the 2 FDTI USB to serial adapters. It will not 'see' my edge port4 even though the Basic Stamp and SX-KEY software will work with the EDGE Port/4
links:
My band's website
'Ping' Chris Savage (Parallax), I've seen him on here once or twice today, he's the Windows USB GURU. He'll probably be able to offer more info.
After I run the FTDI installer, there is no entry in Add/Remove Programs. Is that normal? I do see FTDI files in c:\winnt\system32\DRVSTORE that weren't there after I ran the cleaning utility, so something is getting installed.
Instead of letting Windows search for a driver, is there one I should manually specify?
links:
My band's website
Also, I recommend trying the older FTDI VCP drivers over the newer combo drivers. I've had trouble with the latter on WinXP.
Unfortunately, I have had plenty of experience with driver problems under Windows. I used to work in tech support for Emagic (the music software company that was bought by Apple). I think a quarter of my calls were from Windows users with driver issues.
links:
My band's website
BTW, I just double-checked which driver I have installed, and it's 2.00! I thought sure I was using build 2176 of version 1.0 and can't figure out how the new CDM driver snuck in there. Oddly, despite my prior problems with it, it seems to be working fine.
In Device Manager on your machine, what's the name of the FTDI driver under "Universal Serial Bus controllers"? Double click it and go to the Driver tab and click "Driver Details..." What files are listed?
I really appreciate everyone's help. This is driving me nuts. I can't think of anything I changed since the last time I successfully used the Propeller Tool with a USB device. I ran the SX-Key Editor a couple days ago. I might have installed a new version of StampPlot. I don't use the Windows computer for anything but Parallax stuff. It's not connected to the Internet or even to my LAN. Phil, if it wasn't for your PropSTICK, I wouldn't have any Propeller at all.
links:
My band's website
I can't imagine all three devices stopped working at the same time (unless someone hit my house with an EMP that only affects FTDI chips). I guess my Windows is gummed up. It looks like another round of wipe and reinstall. God, I love Windows.
links:
My band's website
G
links:
My band's website
What did you get when you let V1 of the propeller tool install your driver?
I'll try calling Parallax tech support tomorrow to see if they can come up with something I haven't tried yet. After that I give up.
links:
My band's website
Dave
Dave Andreae
Parallax Tech Support·
links:
My band's website
