midi i/o on the sx?
I've seen the sx used for midi input with a basic stamp 2, I was wondering if the sx could be used alone for midi input and output.
I'm asking because I want to make midi devices, but I need a cheaper solution than using the bs2. I've seen the uart tutorial for the sx, but I didnt know if this solution would work with the baud rate midi uses. Also, I plan on using serial input from devices like trackpads, ps2 controllers while getting clock data from an external midi controller. Would this be possible on a single sx chip?
Any insight would be super, thanks!
· The SX can easily handle the midi baud rate. I'm not sure about the electrical interface, I don't know if midi uses +/- 12V like RS232.
· You would most likely need to receive midi with an interrupt routine so you don't lose any information.
Sound like an interesting project, I think the SX is up the job.
[noparse][[/noparse]edit] Here is a link to a Nuts & Volts (magazine) article that does pretty much what you need.
http://www.parallax.com/dl/docs/cols/nv/vol6/col/nv122.pdf
Bean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
Post Edited (Bean (Hitt Consulting)) : 12/31/2006 4:16:59 PM GMT
Just one more question...
Does the proto board work with the SX-Blitz? I only see the SX-key mentioned in the documentation.
thanks for the fast reply!
Jeff T.
