VGA In
Hi All,
I want to receive a high res VGA signal in, and then convert that to an LED display ( several hundred across ). Is this posssible, doesn anyone have an object which can read a VGA signal in?
Cheers
Peter
Cheers
Peter
The existing high resolution drivers are mostly for use with text so the driver only needs a screen buffer for the text characters. The highest resolution that can be done with two cogs is 1024 x 768.
To answer your question more directly: No, there isn't an object and there likely is not going to be for standard video input (either TV or VGA) because of the external circuitry needed and the fact that there is special shift register/counter circuitry on the current Propeller chip to support video output, but no corresponding circuitry for video input so all of the work would have to be done by the processor(s) directly and they're not fast enough for the task.
Would it·be possiable to build a Propeller based electronic circuit that would process a VGA input signal
and store a certain amount of the processed video signal·as data in memory buffers?
Obviously, the propeller could only process the signal at around 80mhz or so.
My guess is this would not be at +30fps which is needed for fluid motion (correct ?)
and the input signal speed would need to balanced with the processors signal processing·as not to drop frames.
If this is possiable, then the Propeller would be able to manage still frame video presentations,
even some types of buffered VGA animations.·Things that you would see in a powerpoint
presentation. Lower speed stuff.
Could it be done with multi-propeller synchronized Parallel Processing· ? (IEEEkkk I·bit myself)
But, then again, Insted of VGA input, if you just had the video in a file. or other, like SD card
then you would not need any Video input processing, you would just need to read the stored data
and display it. Using the LED Matrix as the final memory area ?
Is this correct ? Please correct my mistakes.
Thank you,
-Areal Person
I have a tree growing out of my head, but
what do you expect ? I'm a programmer.
Post Edited (Areal Person) : 1/1/2007 2:16:34 AM GMT
What I'm talking about when I say "dipping into the ocean" is that you could just use an ADC with a good sample-hold to take snapshots of the incoming signal and process them one pixel at a time slowly. All you need to do is have accurate timing from the sync signals. Let's say you can only process fast enough to handle every 10th pixel. What you do is you sample columns 0, 10, 20, etc., then on the next frame you delay exactly 1 pixel-time interval from the HSync, by means of a counter, and then sample columns 1, 11, 21, etc.
The idea is based on research I did on how commercial VGA signal converters work many years ago when someone needed to convert a proprietary video signal to VGA. It was the first project I did for a real, paying client (I was still in high school), but it turned out that rather than having to build a real converter, all I needed to do was build an adapter because a good multisync VGA monitor can sync to darn near anything. Thanks to the plethora of kinds of computer graphics modes, modern monitors have to be able to handle almost anything you throw at them, and they do it well.
I really want to see someone get the Propeller to process video input. As a hack challenge, I plan to build a Propeller based TV receiver inside of an Altoids tin, and this subsampling technique is why I think it will be possible. I will still need extra circuitry to tune in the TV signal and separate out the sync signals, and I will probably ignore color; I will just be sampling the luminance signal with a sample-hold ADC.
I hope to do the same with the Propeller. Actually I hope to be able to downsample a ntsc video signal into a 128x128 grayscale bitmap, display it on a vga monitor, and serve it over the internet via my WIP (work in progress) tcp stack. Of course I will probably end up with something like 0.01 fps, but it should be good for still images such as outdoor scenery, etc.
Attached is an image from the project that I noted earlier.
Harrison
