how to connect a FTDI 232 chip with bsp2
Hi to everybody,
can anybody know how to connect a ftdi 232 chip with a bsp2 ?
thanks a lot
S.D
thanks a lot
S.D
·· How you do this will depend greatly on whether the BS2p is a module or something you’ve integrated (or plan on integrating) into your own design. ·A Module will expect RS-232 inverter signals, so you would follow the schematic for our PDB, which shows these connections. ·
·· If, on the other hand, you’re integrating the module, please see the attachment for an example of interfacing the TTL level signals, since there are a few things that need to be addressed on a BASIC Stamp Module or it will not respond. ·In the schematic you’ll notice the diode and the pull-up resistor…Without them (as well as the 4.7K echo resistor) you won’t be able to program or identify the BASIC Stamp. ·Take care.
