New to microprocessor control
Hello all,
I am looking into the possibility of learning microprocessor control to monitor and control the environment in a backyard greenhouse·using a closed loop system.
I’ll need to do the following in order to be successful at this:
Since this is a first for me, I was wondering if the BS2 in conjunction with other interface hardware would be a good starting point? If so, I would also like to know if I could eventually turn this design into a standalone controller to operate on it’s own after the closed loop system has been debugged and proven to work?
Any feedback would greatly be appreciated.
Edge
- Control temperature via heaters and or exhaust fans
- Humidity levels
- Light cycles
- Watering schedules
- Co2 feeding schedules
Edge
If you look here ,this should be a good start.
Brian
www.parallax.com/dl/docs/prod/sic/Web-PC-v1.0.pdf
http://www.parallax.com/dl/docs/books/edu/WebAppliedSensors-v1.4.pdf
Edge
