Redefinition of Two Bytes as a Word Variable in SX/B? — Parallax Forums
Sparks-R-FunSparks-R-Fun Posts: 388
edited 2006-12-29 19:40 in General Discussion
Does anyone know what I need to do to redefine two existing byte variables for use as a word variable using SX/B? The goal, of course, is to make maximal use of variable space.
For example, if I have the following:
Temp1 var byte
Temp2 var byte
What must I do to declare Temp12 as a word variable occupying the same memory space as Temp1 and Temp2 combined?
- Sparks
  • JonnyMacJonnyMac Posts: 9,796
    edited 2006-12-29 18:05
    Yes, make your declaration a word so that SX/B knows how to deal with it as a 16-bit value. You can get to the constituent bytes after the declaration.
    tmpW1    VAR    Word
    Will actually define two bytes that you have access to:
    tmpW1_LSB
    tmpW1_MSB
  • Sparks-R-FunSparks-R-Fun Posts: 388
    edited 2006-12-29 18:40
    JonnyMac,
    Declaring the word variable first before the shared byte variables was the trick I was seeking! Thank you.
    - Sparks
  • BeanBean Posts: 8,129
    Sparks,
    In many cases a single element array can be used too.
    temp1 VAR Byte (1)
    temp1(0) = 5
    Arrays are stored differently than regular variables (even single element arrays). So there can be many more of them. They won't work in very case thought (like as a FOR...NEXT control variable).
    Bean.
    Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
    "USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
