PWM Problem
I thought that this code, a modification to the PWM example in the counter application note would give me a 20kHz period.· The measured values (Parallax oscilloscope) are approximately 50Hz (actual value 48Hz).· I'm off by a factor of 400.· I did a simple Spin test to toggle a pin at 1kHz and it tested out OK on the oscilloscope.
''Demonstration of PWM version of NCO/PWM counter mode CON _clkmode = xtal1 + pll8x _xinfreq = 10_000_000 VAR long parameter PUB go | x cognew(@entry, @parameter) repeat parameter := 1000 'a constant here locks to value x percent high waitcnt(1_000_000 + cnt) 'wait a little while before next update DAT 'assembly cog which updates the PWM cycle on APIN 'for audio PWM, fundamental freq which must be out of auditory range (period < 50µS) org entry mov dira, diraval 'set APIN to output mov ctra, ctraval 'establish counter A mode and APIN mov frqa, #1 'set counter to increment 1 each cycle mov time, cnt 'record current time add time, period 'establish next period :loop rdlong value, par 'get an up to date pulse width waitcnt time, period 'wait until next period neg phsa, value 'back up phsa so that it jmp #:loop 'loop for next cycle diraval long 3 'APIN=0 BPIN=0 ctraval long %00101 << 26 + (%000001 << 9)+ 0 'NCO-D/PWM APIN=0 BPIN = 1 period long 4000 '20kHz (50µS period) (_clkfreq / period) time res 1 value res 1
