BS2
sakulanaruto
My Dear:
I try to set 8 ultrasonic sensors on the Boe - Bot with the BS2 ,
and the 8 ultrasonic sensors connect to 8 pins of the BS2 ,
if I want the BS2 to process the 8 pins simultaneously (let the 8 ultrasonic sensors emit simultaneously),dose this way work ?
how can I write for the code using BS2 programming??
Best Regards ,
Peter Chou,
Best Regards ,
Peter Chou,
The propeller chip, however, can do this. It has 8 independent cores, known as cogs, that could each process a sensor. If you might be interested in a Propeller-based robot controller, see this one: www.wulfden.org/PRC/
Doing all 8 "simultaneously" could be a problem. If one 'hears' echo's coming from another unit -- how do you insure that the sound from #1 (for example) bounced off what #1 was pointing at? It could have been an echo from what #4 was pointing at.
And even a fast processor might have a problem starting the 'ping' at exactly the same time. Any delay in any sensor's start of ping could throw off the distance measure of an other sensor.
