I have a mini Pololu 8 servo controller I want to use the BS2 with this controller, has any one a program sample or knows of a website where I could find one? thanks Hank
I believe that the folks at Pololu can provide you a small sample program to get you started... I had played around with their 16-Servo Controller back about 5 years ago... I was able to figure it out from the documentaion and just one or two e-mails with their very responsive Customer Support.
I have played with it quite a bit using Pololu's supplied Stamp codesupplied in the datasheet for the "3 Amp Motor Controller with Feedback User's Guide" and some that I hacked from that.
I like it! (Of course, I also like Parallax's Motor Mind B quite a bit.)
I found this and started using it.
http://forums.parallaxinc.com/www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&krypto=6pWdQhy2AZPZ2sD8W5xEl6aJV6WqDHEGqOKNa%2FdOSS9%2BxO5uYYYPAtzcp5DbERrVw%2Bkl%2Bd7JFjlh%0D%0Ae5nWuhlH7I%2BTNq3tTkoG&ddkey=CookieLogon
I have played with it quite a bit using Pololu's supplied Stamp code supplied in the datasheet for the "3 Amp Motor Controller with Feedback User's Guide" and some that I hacked from that.
--Bill
You are what you write.
