Resitance calculation
I have a device that needs 30 volts @ 450 mA and I have a power supply that is 30 volts @ 1 amp what is the calculation I do to figure out the right resitor I should use to read my criteria, Is there a good website which can do this calc also, I have tried the LED resistance calculator websites but they do not have enough fields for me to fill in desiered amperage and established amperage. thanks much!
PAR
Think about things you plug in at home. The wall socket is 115V. You can power a 15A air conditioner or a 100mA air freshener without worrying about the current they need.
-Martin
Martin Hebel
StampPlot - Graphical Data Acquisition and Control
AppBee -·2.4GHz Wireless Adapters & transceivers·for the BASIC Stamp & Other controllers·
