Servo and Sonar — Parallax Forums
Servo and Sonar
ZactlyZactly Posts: 7
edited 2006-12-29 19:14 in Robotics
Question
I am writing a code to have two sonar mounted back to back on a pole extending from a servo. The servo rotates 180 degress while the sonar pulse.
Right now I am running 5 variables interpersed in the loop for the servo to run the sonar which takes up a lot of code room.
When the servo turns and the sonar pulses, is it better to use a dynamic array, static array, a·preset servo position to trigger sonar·or simply run a half dozen variables to capture data?
  • AImanAIman Posts: 531
    edited 2006-12-26 15:39
    So you are wanting to know which is best?
    My opinion is to use an array and increase by the loops.
    Example
    num = 0
    For counter = 1 to 150 step 5
    Trigger sonar
    capture results
    results = results(num)
    num=num+1
    next
    Then compare the results to figure out which one is smallest.
    num = 0
    if resutls(num) <= results(num)+1 then
    if results(num) <= results(num)+2 then
    etc...
    Course by the time your done it would be as short to simply run multipule variables like you are doing.
  • PARPAR Posts: 285
    edited 2006-12-26 20:15
    Zactly said...
    Question
    You haven't really stated what you want to measure (distance(s), yes; but why? under what conditions? why two (quasi-simultaneous?) measures at 180degs?·what decisions/actions will you take based on your data collecting?)
    How many measurements per rotation? How fast (rpm)?
    Show your current code so folks can see why it "takes up a lot of code room".
    Without knowing this kind of information, it's kind of difficult to speculate what problem you wish to solve or how best to go about inventing a solution.
    PAR
  • ZactlyZactly Posts: 7
    edited 2006-12-27 18:01
    I don't think its that hard to figure out. Its a simple data collection question not·a research·project.
  • PARPAR Posts: 285
    edited 2006-12-27 20:05
    Zactly said...
    OK.
    edited 2006-12-28 17:22
    Ya know, Something else occured to me.
    Why not set up a single variable in your servo loop so it triggers an outside equation once the peramiters get tripped?
    For example
    Servo stuff
    Sonar stuff with return pulse saved under distance
    Next
    If Distance >= saftey area then do something
    Follow me?
    I think I will go with the suggestion of a single variable inside the loop for the servo. It seems to be the best option with the least amount of problems. I can run the variable and slow down the servo loops or run a While statment to handle the servo.
    Thanks AIMan
