BS2P24 won't load program
I have a bs2p24 on a circuit board connected to a serial cable to the com1 port on my computer. I have used the schematic that is given in the documentation.
I have done the diagnostics on the bs2p24 checking that there is 7.5V at Vin proper GND and 5V at the VDD.
The Rx is connected to the SOUT and the Tx is connected to the SIN. The DTR with decoupling caps are connected to ATN. and the GND is connected to VSS. Also Pin 6 and 7 DSR & RTS are connected together.
I have diabled the FIFO buffers on com1 and set them to 2400 8n1
I have made sure to reset the chip, but to no avail the chip will not accept programming.
Is there anything else to do but scrap it?
Help
thanks in advance
Cyber_9
PS I do get Loopback and Echo when identifying chip inthe editor.
Post Edited (cyber_9) : 12/26/2006 4:25:07 AM GMT
Help
thanks in advance
Cyber_9
I´ve got the same problem with my BS2sx.
Iám getting "stamp not found all the time".I was working fine up until a week ago.
Tried 2 computers, 3 cables,Loopback and echo are Ok.
Is there a overvoltage protection on the chip in case I load 7.5 V into Vdd ?
That could be what happened . but not quite sure
Subria
I'm using editor Version 2.2.6
and no the vin is 7.5V and the VDD is Powering other chips...
could I be drawing too much power from the regulator?
