dtmf question (straight pins vs crossed pins)
Can someone please explain me the difference between straight pins and crossed pins?
Also, please explain the relationship of the pins to these lookup values or code:
"D84#206B195A3*7C-" for straight pins
"D1234567890*#ABC-" for crossed pins
- Stephen
DTMFER:
DTMF = INL & %00001111
LOOKUP DTMF,[noparse][[/noparse]"D84#206B195A3*7C-"],DTMF 'STRAIGHT PINS
'LOOKUP DTMF,[noparse][[/noparse]"D1234567890*#ABC-"],DTMF 'CROSSED PINS
IF DTMF = "1" THEN DTMF1
IF DTMF = "2" THEN DTMF2
IF DTMF = "3" THEN DTMF3
IF DTMF = "4" THEN DTMF4
IF DTMF = "5" THEN DTMF5
IF DTMF = "6" THEN DTMF6
IF DTMF = "7" THEN DTMF7
IF DTMF = "8" THEN DTMF8
IF DTMF = "9" THEN DTMF9
IF DTMF = "0" THEN DTMF0
IF DTMF = "*" THEN OTHER
IF DTMF = "#" THEN OTHER
IF DTMF = "A" THEN OTHER
IF DTMF = "B" THEN OTHER
IF DTMF = "C" THEN OTHER
IF DTMF = "D" THEN OTHER
RETURN
The rest of the code can be found here:
http://www.repeater-builder.com/pix/rc2.bs2
·· Not sure about straight and crossed pins…Do you perhaps mean common bus key switches and matrix keys?
·················· [url=mailto:n0yox647@[remove-no-smam]iland.net]n0yox647@[noparse][[/noparse]remove-no-smam]iland.net[/url]
PAR
Based on the contents of the CM8870 data sheet, my guess would be that they're speaking about the ROW and COLUMN wires. If they are correctly wired (ROWS = ROWS, COLUMNS = COULUMNS) then you use one of the tables. If however, it's mis-wired (ROWS = COLUMNS, COLUMNS = ROWS) then you use the other table. With that in mind, the justaposition in the table is reasonably easy to see.
What makes NO SENSE at all is the last "-" entry in both tables. That character is not present on a telco-style keypad, or in the DTMF sequence. Thus. for my money, that's an unnecessary entry, although it probably won't hurt anything. Moreover, I can't even see a way for it to be transmitted, as any bit pattern it might present would exceed 4 bits, and there are ONLY 4 data lines (D0-D3)!
Bruce Bates
<!--StartFragment -->
