Anyone out there using the Parallax PDB with a Mac G5, and uploading to the PDB with the existing USB port? If so, which Mac (G5?) and what drivers did you use if any?
I've used a Mac PowerBook G4 and a MacBook with a variety of Parallax USB to Serial adapters including the one on the Propeller Demo Board, Hydra, USB2SER, and PropClip. They work fine with the Mac driver from the FTDI website.
You don't need the D2xx driver if you only want to talk serial to the PDB. The VCP driver provides the Virtual COM Port. Follow the link from Parallax's page to the FTDI drivers page for the latest versions.
I finally got MacBS2 working on the G5. It was a matter of using the correct driver version, FTDIUSB FCP driver v2.1.7. All this time I had v1.0.9 uploaded.
I was having similar issues but have now got MacBs2 recognizing my stamp module (Im using PDB and PowerBook G4), my problem is that Im being thrown an error which says that the stamp is not responing, 'check power'.
Just wondering if anyone has any experience with something like this and might be able to help?
thanks,
piaras
Assuming that power to the PDB is good and the Stamp itself is good then...
Has this particular installation of MacBS2 on this PowerBook ever connected to the PDB and Stamp in question? I ask because one possible error mode is having multiple devices available for MacBS2 to connect to (this shows up as several entries in the Serial Port selection pop-up menu) and having the wrong device selected. If it has worked before then it should be a process of elimination to find the correct port. (Why would there be more ports? If a new serial port device driver is installed, then you'll see new entries appear)
A PDB has USB so you would only need to install the latest FTDI driver to enable the Mac to see the PDB's USB port.
If you happen to use a USB-to-Serial adapter (for some other device you might connect to your Mac or even a Stamp that you have to connect via legacy serial, i.e. a 9-pin "serial" port) then you'll end up with additional serial devices once you install the driver software for the USB-to-Serial adapter.
I wouldn't connect that if I were you...
I'll try re-installing the software, just to check.
The version of the driver I've got is definitely correct though, is there the possiblity of this being a harware issue? Nothing seems to be amiss on the board itself however.
Yes I've been trying the Windows driver also, but it is unable to detect the board. Windows does detect that a device has been connected, however, this is regardless of whether power to the unit is on or off.
What version of FTDI driver have you installed in your G4?
phoban said...
The USB device is recognized when the power is off because the USB circuitry gets power from the USB cable.
I just had this exact problem and it turned out to be a bad USB cable. Have you tried other cables?
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ OS-X: because making Unix user-friendly was easier than debugging Windows
I as well am unable to get my Professional Development Board to work on my Mac, it used to work with my basic propeller board, but stopped responding when I tried to use my pro development board. I have deleted and reinstalled the drivers and bst software from the website, still not working. When I try to detect the propeller, it says no propeller detected. Not sure what else to do, I know the cable is good, and I even tried installing the software and driver on a different mac, but same results....
Darcy,
The Professional Development Board's USB interface is not really any different from any other Parallax Propeller board's USB interface. I use a Mac all the time with BST and the FTDI drivers and it works fine. I've used a variety of Mac laptops and MacOS versions and I've not had problems other than the occasional bad USB cable. Make sure your connections are good, your power supply is good, and the Propeller is properly installed in its socket.
I also run Windows XP under Parallels Desktop so I can run a variety of Windows-only software including some of Parallax's. That works as well ... with the Windows FTDI driver.
So if I were to upload the FTDI VCP driver ( or the D2xx driver?) to the G5, it should be able to see the PDB?
Thank you for your answers.
thanks,
piaras
Vive Le Tour!
Le Grand Depart July 6-8, 2007
Do you have access to a PC anywhere that you could temporarily install the Windows driver and connect the hardware to see if it works there?
links:
My band's website
Our album on the iTunes Music Store
Please contact me in Tech Support Monday morning on this. 1-888-997-8267
help?
