How to compress MOV file from digital camera ? — Parallax Forums
BeanBean Posts: 8,129
edited 2006-12-31 09:14 in General Discussion
I got a digital camera for xmas that will record video (with sound).
But the files are huge, something like 1meg a second.
On my PC they play using Quicktime.
How can I compress these to put them on the web ?
I don't mind paying for an inexpensive program to do it, but free would be much better [noparse];)[/noparse]
Bean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
  • ForrestForrest Posts: 1,341
    edited 2006-12-24 15:28
    Upgrade to QuickTime Pro from Apple - $29.99 www.apple.com/quicktime/technologies/
    or if you had a Mac I'd suggest iMovie and iDVD
  • UnsoundcodeUnsoundcode Posts: 1,532
    edited 2006-12-24 15:57
    Hi Bean, this is freeware. I have never tried this software but the site itself is a mine of information. If you dont get enough compression with this at least with AVI you can import into Windows Movie maker which gives a fairly decent output for web video. I guess you know that FAT limits your recording time and that if you require longer video clips you need to convert to NTFS.
    http://www.videohelp.com/mov2avi.htm
    Jeff T.
  • T ChapT Chap Posts: 4,260
    edited 2006-12-24 21:17
    One suggestion, you may want to check out Sorenson Squeeze to export as FLV or SWF. It isn't too expensive, and is a great program, it will capture DV from cam or open QT files, then compresses based on your settings.
    Flash movies are great for web, very small, excellent quality, universal playability, my experience is that for file size, the quality is unbeatable versus a great compression on QT
    Post Edited (originator) : 12/24/2006 9:58:47 PM GMT
  • BeanBean Posts: 8,129
    edited 2006-12-25 14:09
    Thanks for the sugggestions guys.
    I think I'll try converting the MOV to an AVI, then I can pull it into my "Pinnacle Studio 8". I'm familiar with that, and I make whatever I need from there.
    Happy Holidays· MERRY CHRISTMAS!!!
    Bean.
  • Beau SchwabeBeau Schwabe Posts: 6,575
    edited 2006-12-27 06:32
    Bean,
    I have been in your same shoes with our new digital camera, and I have done exactly what you describe above... do a Google search for mov2avi and you should find something "Freeware" that works.
    Beau Schwabe
    IC Layout Engineer
    edited 2006-12-27 12:57
    I tried the Rad tools, but it won't convert the sound...
    I'm still looking...
    Bean.
    edited 2006-12-27 16:39
    Hi Bean, I knew my camera also took video clips and after reading your original post was curious as to what format my video would be. It turns out that it is mov so I downloaded the mov2avi and converted a short mov clip I shot this morning. Without doing anything with the mov2avi software apart from selecting the mov file and a couple of different codecs I produced two successful clips sound and all. So (assuming you have sound in the original mov file) I would guess that the problem either lies in the codec you selected or the record settings of your audio card. As a note the first codec I tried was Huffyuv v2.1.1 which is a free download, the link should be on videohelp.com somewhere.
    Jeff T.
  • Tronic (Greece)Tronic (Greece) Posts: 130
    edited 2006-12-27 16:51
    I always use Super converter for non standard video formats! It supports all known formats and its free! yeah.gif
    Try it in the link below:
    http://www.erightsoft.com/SUPER.html
    Thanos
    Greekbotics: Greek Robotics Forum
    (Translate it using Babelfish)
  • Special_KSpecial_K Posts: 162
    this may be no help at all... but have you tried
    http://www.versiontracker.com
    they may have some nice freeware for video file compression
