Interfacing bi-direction serial 5V devices to the Prop !?!
Hello all!
Firstly, I would like to wish everybody a Merry Christmas and a happy new year for this holiday season.
Now back to the topic at hand, I have read through the sticky thread,·HOW TO SAFELY INTERFACE A 5V SIGNAL TO THE PROPELLER?, and although it is·a little 'cloudy' at points, I understand the parts about one-way communication between different devices.
But would a simple resistor·be suitable for bi-directional communication between·a prop and Parallax's GPS module,·and·which value is best? 4.7K?··
Chris
Chris
"would a simple resistor be suitable for bi-directional communication between a prop and Parallax's GPS module" -· for receiving the RAW signals yes, a 4.7K resistor would be fine.
For sending it depends on what the input threshold voltage is for the 5V device. (<--This applies to any 5V device connected to a lower voltage interface.)·· ... I could not find this
information on the GPS datasheet, and I no longer have my setup connected.· But if I recall, the input voltage threshold is around 4V.· You could try this trick using a diode to the
GND connection of the 3.3V regulator supplying the Propeller.· Effectively this level shifts the Propeller I/O so that it outputs .6V for a logic LOW and 3.9V for a logic HIGH.
I haven't tried this with the Propeller, but I have used this method with other processors running at 2V.· It might be just enough to get you within the input trigger threshold.
Beau Schwabe
IC Layout Engineer
I'm in the process of designing a·PCB·for a hand-held device so·I·need·some idea of the layout to accommodate·the additional components. I will include a·jumper (and pull-down resistor) to manually select RAW mode·if I have problems after proto-typing.
Thanks again.
