BS2 pwm
·I have a 379 peterbilt truck, the speed sensor on the truck is supposedly sending·333 pulses per second at 20 mph, ·is that enough pulses for the BS2 to recognize and debug the signal, if not do you have a solution?
Many thanks to the input.
-Tobias
-Tobias
-Tobias
The wheel sensor is a magnet with a coil around the magnet. It generates a sine wave by a reluctor on the axle that has 48 teeth.
At low speeds @5 MPH the voltage is @ 2V p-p and it increases to @ 5V p-p at @ 10 MPH after 10 MPH the frequency changes and the voltage remains constant.
The systems seems to be similar to the Peterbilt.
I have the same question as Tobias.
-Martin
Martin Hebel
StampPlot - Graphical Data Acquisition and Control
AppBee -·2.4GHz Wireless Adapters & transceivers·for the BASIC Stamp & Other controllers·
-Tobias
