stack trace corrupt
I wrote a code to control some equipment, and it was working fine, until I made a small modification (I added one case in a switch statement) and all of the sudden my Javelin locks up.
I used the debugger, and found out now that I get a message [noparse][[/noparse]Error IDE-0015] Stack trace is corrupt.
Could someone point me in the direction of where to look to resolve this problem?
This error seems to appear when I call a·method that was executing perfectly fine before, and all of this even before I even reach the condition for the·new case that I added. This does not make much sense to me.
Any ideas?
Thanks.
Lasers will rule the World!
Any ideas?
Thanks.
regards peter
Anyway, it seems to run smoothly now.
All I needed to do was to step back, write down all the variables in my entire code (the all thing is getting a bit complex, I have 5 different classes and 3 libraries, and there are 2 pages of just variable definition in total), and VOILA!! I had re-defined 3 arrays in 2 different classes.
But thanks again for the response.
