Infra Red - Remote Control - Turn on/off the TV
How can I program an infra led and a push button with my BOE and bs2pe that when I press the push button it sends the appropriate signal to turn on (or off) my sony TV.Is it possible or not?!
(I have already experienced working with ir detector and a remote to control my boebot.)
Thank you
Thank you
Now, the 'pattern of bits' consists of 1.2 mSec and 600 uSec pulses (for the Sony protocol -- other's are different). So it might be easier to make a 555-based 38,500 Khz oscillator, and 'gate' that using PULSOUT (which has the required 2 uSec resolution).
Some others may be able to give you links to appropriate circuits.
