Propeller EEPROM Upgrade ?
Ok,
I'm trying to upgrade·my single 32k·EEPROM (DIP) on my breadboard setup
to 4-64k Ramtron FRAM chips. They come in SOIC and DFN.
I checked on prices for SOIC to DIP converters and there $7.00 each.
What should I do to be able to use the FRAM chips on my breadboard ?
Whats the best solution ?
-Areal
I have a tree growing out of my head, but
what do you expect ? I'm a programmer.
-Areal
This is a bit of work, but should be straightforward. Both the sticky thread and the Philips website discuss in great detail what you have to do to use a mixture of +5V and +3.3V I2C devices.
file system, you can almost treat the SD card as just one big 512MB EEPROM.
The uALFAT device does talk I2C and the DOSonChip and Vinculum devices are supposed to have this capability some time in the future.
Post Edited (Mike Green) : 12/20/2006 7:13:37 PM GMT
Paul Baker
Thanks everyone !
I thought I could just plug in the·Ramtron FM25CL64-G 64k (2-wire) SOIC-8
with a (SOIC to DIP adapter) ? they 2.7v - 3.6v that will work
with 3.3v ? Right ?
The bigger chips are 5v - Mouser has them in stock.
2-Wire is the same as I2C Correct ?
-Areal
Post Edited (Areal Person) : 12/20/2006 7:27:02 PM GMT
Paul Baker
The 24LC256 is 32K bytes. The 24LC512 is 64K bytes.
Gotta remember, some folks are green
-Areal Sad Situation
I was wanting fast r/w memory·so I could start working with pointers
Now, I gotta bunch of 8k byte chips.
Post Edited (Areal Person) : 12/20/2006 8:40:35 PM GMT
Paul Baker
I dont care what kind of memory, as long as it's FAST, wont ware out
and I can hook it up to the Propeller ?
Simple as possiable. However, I know that may be impossiable.
I think I'm back to DRAM.
I got a·BIG stick that runs on 3.3v
http://www.datasheetcatalog.net/datasheets_pdf/H/Y/B/3/HYB39S64400AT-8B.shtml
How hard to hook that up one of the chips on this ?
I would desolder it first. It has multi banks
-Areal
Post Edited (Areal Person) : 12/20/2006 9:07:56 PM GMT
large static RAM like the Cypress 62167. It's got 18 address pins and 16 data pins but you can use it in a x8
configuration if you want. With a chip like this, you slam the address on one set of pins, set the direction of the
data lines to read, toggle a few control lines and *bam* your data is ready to read.
I'm still gonna hook up one of the 8kbyte FRAM chips
...(As I spent ALL my money on a ton of them)
But I'm going to need somthing bigger.
The dream was fun while it lasted [noparse];)[/noparse]
I think I need a·to read some instructions on how to drive
RAM chips, I dont know how to hook up the Pins, I never
did·that before, I would like to learn how.
Any advise ?
Thanks all
-Areal
Post Edited (Areal Person) : 12/20/2006 9:51:33 PM GMT
I have some help 4 U!
Here·are some Pics of a of my simple Fram hook up:
I'm using a Framtron: FM18L08-70-PG256K.
Mouser Part# 877-FM18L08-70-PG
This Fram is a·256K, (32K x 8bit), 70ns Access time, 140ns Cycle time, 3 volt, 15mA Active current, 15uA Standby current, Parallel FRAM hooked up to a PropStick.
in other words it is a 32 Kilo byte storage device. I will explain.
I hope you don't mind this Lesson, but it sounds like you could use the help.
1st:
··· ·When reading Memory storage amounts you must be aware of (B), verses, (b). Almost all descriptions are going to be in (b, Kb, Mb, Gb), But in·amounts larger than (b), (K, M, G), they often drop the (b)·this means that you must do some basic Math: divide the # of (bs) by 8, (IE, 64Mx8 (64 Mega Bits) = 64/8 =·8 Mega bytes of storage, NOT 64 Mega Bytes.)
Note!
·In all digital electronic memories·8 is the magic number! hear's how it goes:
1· bit = A bit······ (A single Switch or·Transistor, 1 wire Parallel buss)
4· bit = A nibble· (4 transistors, 4 wire Parallel buss)
8· bit = A Byte * (The most common Buss Size for older CPUs and current Micros. I.E. Basic Stamps, SX chips ect.., 8 bit Buss)
16 bit = A Word·· (Basic Stamp P40 and SX 52, 16 bit Buss)
32 bit = A Long·· (***** Propellers******, 32bit Buss)
So, it is a good practice to divided the stated Storage amt by the buss size to gain an idea of how large the storage area is. (E.g.. If you had a 64k x 1b then 64/1=64k bits you would need 8 of them in parallel to make 64K Bytes, this is what most of us are used to when we buy Memory).
··So lets assume that·you need 1Gig, (1,024 Million Bytes = buss size 8b or larger), for·a laptop so·you go out and·buy a 1 Gig DDR DIM, but if you look at the Dim you will see some arrangement of 2, 4, or 8 ICs that have the same part#(these are the Ram). You may find·one or two chips that don't have the same part#(these are the Address and control busses).
So, in order to get the right amt of storage on the DIMM they must have used some arrangement of (1024/8b= 1024/1B) Think about it:
1 Gig / 32bit buss = 1024/32 = 32 Million Longs or if we want to work by groups of 8bits then; Some how they must·use an arrangement of 1024MB/8bits / 32bit buss?, Not so! they could use 32 ICs but that would take up a huge space. there is an easer way!
Let's go back and look at the Number of ICs on the DIMM:
· 8 ICs = 128MB each IC (8x128=1024)
· 4 ICs = 256MB (4x256=1024)
· 2 ICs = 512MB (2x512=1024)
If you see Ram like: 1Mb bytewide ram: then Bytewide refers to the buss size in bits and we know that a Byte is 8 bits so Bytewide means·1 Byte·= 8 bits wide at one time. So, all this Brakes down to mean that:
1Mb Bytewide RAM = 1024Mb/8bits= 128K x 8bit buss = 128K x 1byte = 128K bytes of Actual Storage! NOT 1 Megabyte!
So, you see that all this talk of Micro controllers is really talk of small scale·CPUs, But the Propeller has broken down the wall of bit, Byte, Buss, Oppression. Every time I read the boards for any Micro I am always amazed by what has be misconstrued. I guess the fact that the Micros have most often been used to Interface directly to I/O has some how made every one forget that no matter what brand or scale the Micro may be, it is still just a CPU that wants to hook up to RAM and·other mass storage, but·it has been·made user friendly thanks to hard work on the part of the IDE Engineers. Now!·You and I don't have to learn Mnemonics or ASM unless we want or need to!
whew!
Enough of that!!
Here are the pics:
In the pics you will see, (if you look close):
· 11 Black wires are·Address Buss, (11 bits wide = A0-A10 on the Fram).
· 8·· Red Wires are the Data Buss, (8 bits wide = D0-D7 on the Fram)
· 3·· Green Wires are Control Buss, (3 control lines CE=Chip Enable, WE=Red/Write Enable, OE=Output Enable).
In one of the pics is a Propeller pin out with the·Framtron Buss connections Annotated in Red ink. (I hope you can read it)
Timing is simple, and fairly straight forward! (Although I've not yet had the time to finish programing my·FRam I/O spin Object, I do have the basics in· place.) for there are two ways to write to the fram and there is a R/W pre charge to consider, but It's still simple!
READ from Fram:
1)·Make sure WE·is High (to prevent an automatic write cycle)
2) bring the CE from·Low·to High (Pre charge)
3) load all the·Address, 11 bits at a time, onto the address buss. (If you use less than 11bits, then you can't·address the whole Fram)
4) bring the CE from·High·to·Low (Start Read)
5) bring the OE from·High·to·Low (Make FRAM Data Buss·an Output·so as to write Data out to the Propeller waiting for the Inputs on 8 bits.)
6) Fram will load data stored at Address#X·onto the Data Buss in sets of 8 bits at a time. (The Prop should Be waiting to receive Data in 8 bit increments) (how you do that is up to you)
7) bring the CE from·Low·to High (Pre charge), (get ready for next operation)
8) bring the OE from·Low·to·High (Make FRAM Data Buss·a tri state·Output·so as to·ignore the Data buss·with the Propeller, on all·8 bits.)
Write To FRAM in CE controlled mode: (safer than WE controlled mode)
1) bring the CE from·Low·to High (Pre charge), (NOTE! the State of OE does not matter once this step is done.)
2)·bring WE·Low (to·Set up an automatic write cycle)
6) load data·from the Prop onto the Data Buss in sets of 8 bits at a time. (This timing is up to you, but it should be tied to CE, OE·& WE)
4) bring the CE from·High·to·Low (Start write)
5) The Data on the Data Buss should now automatically have been Latched into the FRam and stored for ever at that address unless you over write it.)
Well there it is!!!!!!
Hope it helps you,
HAPPY Holidays to all,
IAI CAPTIAN·
P. S. Here·are links to Ramtron.com Data sheets:
http://ramtron.com/doc/Products/Library/Literature.asp?ID=1
Here is the link direct to the FM18L08 (PDF):
http://ramtron.com/doc/Products/Nonvolatile/Detail.asp?ID=13&gr=6
IAI (Indigenous Alien Intelligence),
The New View on Machine Intelligence.
Because There is nothing Artificial about it!
I really needed that, it really helps a TON, you explained that very well.
I'll need to review and study the information over and over again. but, I'm
going to do that setup as soon as I can get a FRAM chip.
That is really a nice example.
Thank you very much for that.
-Areal
