BS2 <-> SPI or UART Interface
crgwbr
I'm planning on using a device with an SPI and UART·interface.· The Shiftin and Shiftout commands should work with the SPI and the Serin and Serout will work with the UART, right?
NerdMaster
For
Life
NerdMaster
For
Life
There is one sort of notable exception. Maxim/Dallas makes the MAX-3100 which is a UART which is controlled by an SPI-like interface. The OUTPUT side of the MAX-3100 UART operates in an RS-232 like manner.
Bruce Bates
<!--StartFragment -->
crgwbr
NerdMaster
For
Life
Paul Baker
NerdMaster
For
Life
Paul Baker
NerdMaster
For
Life
Paul Baker
·· I will be on the forums through next week and I will be working on some of the code I meant to have posted.· I will post a Serial example and hopefully with Mike’s Propeller Code I can see what I did wrong in my first attempt at SPI and get an example of that.· For the BASIC Stamp I think that would be the better way to go, although I did not have any issues with the serial other than handshaking being required.
