Passing Arrays
Could someone provide the proper syntax for passing an array by reference to a spin function, and then reading and writing the array elements from that function.
For Example:
VAR
· LONG Array[noparse][[/noparse]100]
PUB ArrayTotal(ptr_array, size)| index, sum
··sum :- 0
· REPEAT index FROM 0 TO (size-1)
··· sum += LONG[noparse][[/noparse]ptr_array][noparse][[/noparse]index]·· ' This syntax seems to provide strange results in some situations, but so does LONG[noparse][[/noparse]ptr_array+index]
· RESULT := sum
Questions:
1.· Is this the proper syntax for addressing in this type of situation?
2.· Can the [noparse]/noparse brackets of the LONG instruction contain expressions, such as LONG[noparse][[/noparse]ptr_array][noparse][[/noparse]index-1]?
Thanks in advance for the help.
For Example:
VAR
··sum :- 0
· RESULT := sum
Questions:
To call, use ArrayTotal(@Array, 100)
LONG[noparse][[/noparse]a][noparse][[/noparse]c] is identical to LONG[noparse][[/noparse]a+4*c] (except they use different bytecodes
and LONG[noparse][[/noparse]a][noparse][[/noparse]c] is shorter and probably a bit faster.)
BYTE[noparse][[/noparse]a][noparse][[/noparse]c] is identical to BYTE[noparse][[/noparse]a+c] (with the exceptions given above).
Note that Long[noparse][[/noparse]a][noparse][[/noparse]0] is always the same as Long[noparse][[/noparse]a].
Tell us more about the strange results you are seeing.
