Sonar and IR
AIman
Question - if a robot is moving VERY VERY slowly, which is better IR or Sonar?
This robot has a two inch wheel and moves at about 7 RPM / 5 feet a minute. It needs to be able to scan from 1 inch away to 15 feet.
Which is better, Sonar or IR and why?
I am actually looking at using 2 sonar mounted back to back on a servo for 360 vision with IR coming off all 4 sides of the robot. Possibly one or two IR front and back underneath for edge detection.
By the way, if IR triggers while sonar is running will they two interfer with each other?
My first reaction is no they won't but I would like to be certain.
FWIW, the timing of send/receives for either of these technologies is such that it would be very rare that they would be happening at the same time...unless you are using different processors (or COGS) to handle them...so this might be a moot point, anyhow.
