Temperature Sensor
Could someone tell me if they know of good temperature sensor that I can interface with a BS2 for a reasonable price?
The sensor should have the capability to measure temperature at multiple ranges (at different distances). Any detail information is very appreciated!
Thank You,
DosEdge
Thank You,
DosEdge
·· Please see the following link for a list of sensors and their ratings/ranges.· Take care.
http://www.parallax.com/html_pages/products/componentshop/sensors.asp
You set up your hardware, place a calibrated thermometer or one that has the accuracy you want with your transistor, and determine the transistor voltage as a function of the temperature around it, over the temperature range of interest. You then store this relationship of voltage-versus- temperature in a look-up table in your STAMP. Then when you read a voltage on the transistor, you look up the corresponding temperature from the table.
The transistor should be placed in some kind of water-proof container if you are measuring the temperature of liquids.
Post Edited (Tom Walker) : 12/19/2006 2:55:18 PM GMT
