Testing STAMP code
I know I can use a debug command to test the code. I want to send electrical signals in real time to the STAMP. I want to create a CSV file or similiar that contains two columns. The first column would be time and the second column would be the amount of pulses for that corresponding time. So the file is read by software and then outputs the signals in real time through the serial port or another port. I am sure someone has something that will do this. Anyone know?
As far as getting the Stamp to respond to the commands, I suppose you could use DEBUGIN to tell it to wait for instructions on the programming port, or use the standard SERIN command and work out the timing.
Roger Pierson
Senior Electronics Technicain
DTI Assoicates
Take a look at StampPlot and StampDAQ on the Parallax web site.
bruce Bates
<!--StartFragment -->
