WATCH error?
Chrisp_oz
I wonder if I'm doing anything wrong. I've been trying to set up a watch for one bit in a register and didn't know why the value shown was always wrong until I·saw the program listing from the compiler:
At the bottom, looking at the watch statements, flags.1 points to address $108 instead of $008. Why is that? I tried udec and ubin with similar results.
Christian
1 07FA 0F7F device sx28l,oschs3 2 07FA 0F7F device turbo,stackx,optionx 3 =00000000 IRC_CAL IRC_SLOW 4 07FF 0A4C reset main_program 5 =0007A120 freq 500_000 6 7 ;*********************************** 8 ;Bank definition 9 ;*********************************** 10 =00000008 global_org = $08 11 =00000010 bank0_org = $10 12 =00000030 bank1_org = $30 13 14 ;********************************** 15 ;Variable space 16 ;********************************** 17 18 ;Global area 19 =00000008 org global_org 20 21 =00000008 flags ds 1 22 =00000008 time_elapsed equ flags.0 ;Time to collect another sample 23 =00000008.1 half_deg equ flags.1 ;.5 degrees more 24 =00000009 time_cntLB ds 1 25 =0000000A time_cntHB ds 1 26 =0000000B wait_cnt ds 1 27 =0000000C temp_value ds 1 28 =0000000D temporary ds 1 29 30 =00000007.5 DS_RST equ rc.5 ;Reset line for DS1620 31 =00000007.6 DS_CLK equ rc.6 ;Clock line for DS1620 32 =00000007.7 DS_DQ equ rc.7 ;Data line for DS1620 33 34 ;Messaging data area BANK 0 35 =00000010 org bank0_org 36 =00000010 mesg_data ds 1 37 =00000011 mesg_in_data ds 1 38 =00000012 bit_counter ds 1 39 40 =0000000C watch temp_value,8,udec 41 =00000010 watch mesg_data.0,1,udec 42 =00000108 watch flags.1,1,udec 43 =00000008 watch flags,8,ubin
Christian
If I recall correctly, the "1" in "$108" tells the SX-Key which bit to watch. Try changing the bit number and you should see that value change to match it. Also, there was a problem watching individual bits that I thoought was fixed. I'll have to see if it's there is still a problem. In the meantime, just watch the entire byte and check for the status of the bit by eye.
Thanks, PeterM
I forgot to add one thing, when I change the bit in the watch window, instead of changing bit 1 in register $008, I can see bit 1 in register $118 change instead.
I'm using SX-Key v3.2.3, is there a newer version than this?
Christian
I believe there still is a problem, and as I recall (not positive) it's different for registers in bank 0 versus other banks.
Could you please explain how they should work ? As I recall, they dont work like the description in the manual.
Cheers,
Peter (pjv)
- Sparks
