simple basic
[Deleted User]
In mike's OS he has·simple basic demo program , how is the program Assigning the the value of 140 to quit·.
········ a += 3 + strsize(a+2)
··········· 138: ' run
················· clearvars
··········· 129, 139: ' then, rnd
·············· abort(@syn)
··········· 140: ' quit
·············· boot.bootEEPROM(boot#bootAddr)
····· else
Thanks ,Brian
····· else
Thanks ,Brian
Brian
··Seem to have a handle on·Peek & Poke .I'm calling up the· readEEprom & writeEEprom in the loader object in your OS .Still trying to wrap my brain around a save comand·.Would·I use a udatebitmapEEprom· from the file system object & then A writeEEprom from the loader object ?
Brian
$59504F43: ' copy <fileFrom> <fileTo> x := \getTextWord(x,@fileName,12,true," ") if x < 0 abort -string("missing <fileFrom>") x := \getTextWord(x,@fileNameTo,12,true," ") if x < 0 abort -string("missing <fileTo>") fileAddr := \files.searchFile(@fileName) if fileAddr < 0 abort -string("<fileFrom> not found") fileAddrTo := \files.searchFile(@fileNameTo) if fileAddrTo < 0 if fileNameTo[noparse][[/noparse]0] == files#altBoot1 if fileNameTo == files#altBoot2 abort -string("can't create **BOOT") fileAddrTo := \files.searchFile(0) if fileAddrTo < 0 abort -string("can't create <fileTo>") fileChange := false else fileChange := true return processCopy ' Options were copiedThe second section takes care of getting permission to overwrite an existing copy, then actually does the copy.
processCopy: if fileChange dsp.str(string(" Overwrite? (Y/n) ")) repeat t := key.getkey if t == dsp#Cr t := "y" until t == "Y" or t == "y" or t == "N" or t == "n" dsp.out(t) else files.markNewName(@fileNameTo,fileAddrTo,fileAddr) t := "y" dsp.str(string("Created")) if t == "Y" or t == "y" if fileChange files.writeFilename(@fileNameTo,fileAddrTo,fileAddr) dsp.out(" ") j := dsp.windowCol fileAddr &= $7FF000 ' Remove option bits fileAddrTo &= $7FF000 ' from addresses repeat i from 0 to $7FE0 step 32 dsp.decFixed(i,5) dsp.out2(dsp#MoveX,j) if i == $7FE0 k := 16 else k := 32 if not ldr.readEEPROM(fileAddr+i,@b0,k) abort string("copy EEPROM read error") if not ldr.writeEEPROM(fileAddrTo+i,@b0,k) abort string("copy EEPROM write error") ldr.writeWait(fileAddrTo+i) dsp.str(string("Saved")) dsp.out(dsp#Cr)The updateBitmapEEPROM routine is used only to recheck if there are any new EEPROMs attached. It's used during initialization and for the "probe" command.
From what I can tell , the program a person is writing is sitting in the stack.
Would I end up with somthing like this ?
to save:
10 Print " Hello World"
copy "stack" hello_world
to load:
copy hello_world· "stack"
list
10 print "Hello World"
Brian
I'm about four steps ahead of myself , Is there going to be a way to call up the main OS services . I tried to include it , but it made the program over 32k .
Post Edited (truckwiz) : 12/18/2006 1:00:40 AM GMT
