Reflective object sensor
What does it mean when I use this command,
and it results in the debug screen displaying [noparse]/noparse][font=WP MultinationalA Roman]l[/font over and over again ? My stamp is connected to a Reflective object sensor, and I'm using the serin command to receive whatever is reflected back to the object sensor. Are there any examples of how to use a sensor and have it give you a message for whether or not it detects an object ?
Thanks !
' {$STAMP BS2sx} ' {$PBASIC 2.5} SI PIN 6 ' serial input FC PIN 7 ' flow control pin #SELECT $STAMP #CASE BS2, BS2E, BS2PE T1200 CON 813 T2400 CON 396 T9600 CON 84 T19K2 CON 32 T38K4 CON 6 #CASE BS2SX, BS2P T1200 CON 2063 T2400 CON 1021 T9600 CON 240 T19K2 CON 110 T38K4 CON 45 #CASE BS2PX T1200 CON 3313 T2400 CON 1646 T9600 CON 396 T19K2 CON 188 T38K4 CON 84 #ENDSELECT Inverted CON $4000 Open CON $8000 Baud CON T38K4 + Inverted letter VAR Byte i VAR Byte ' FOR/NEXT counter Main: DO SERIN SI, Baud, [noparse][[/noparse]letter] ' receive one byte DEBUG letter ' display on screen PAUSE 10 ' wait one second LOOP ' repeat forever END
Thanks !
lets see what this does... KA BOOM (note to self do not cross red and black)
http://www.solarbotics.com/products/index.php?scdfa-250100084-viewCategory-categoryzq33=true&frm=sbsb
and the document is:
http://downloads.solarbotics.com/PDF/QRD1114.pdf
Thanks for any help !
- Stephen
Is the above program intended to be used with that circuit? (I.e., did someone give it to you and tell you that it "works" with the circuit? Or did you write the program expecting it would work with the circuit?)
PAR
