Outputing 25mhz using counters
Can a Propeller running at 80mhz (5mhz xtal + 16pll) generate a stable 25mhz output using the built in counters? I read in another post that the synthesized frequency should be a multiple of the main clock signal. Unfortunately I don't know what else is required to generate a stable frequency so I am asking this question.
I am asking this because I am going to try to write an extremely limited tcp/ip stack using the Propeller and a ENC28J60 ethernet chip from Microchip. This chip requires an accurate 25mhz clock source in order to generate correctly timed ethernet signals.
Harrison
Harrison
If I did the math right you would load the FRQx register with $1400_0000 which would give you 6.25 MHz (with an 80MHz clock), then use the x4 PLL to get 25MHz exactly.
Bean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
Harrison
