Can BlueSMiRF by parkfun be used in the Education board for Boe-Bot ??
zhang
I want to implement the communication of Boe-Bot Robot with Bluetooth module. I use the BlueSMiRF module by Parkfun at hand. But the hardware connection need RXD and TXD connection. It seems that the education board is not convinient for the connection. Even if I connect the two pins with SIN and SOUT pin of the BS2 and command with serin and serout 16 pin (the phisical pin), the BS2 editor can't found the stamp.
If I do something wrong in hardware connection or program wrong? And can the BlueSMiRF be used in education board?
Looking forward for any answer! Thank you for your patience.
Also, you shouldn't post the same exact thing in multiple subforums in attempt to get a response.
You mean that I can use other pin to do serial communication with the BlueSmirf. If I don't use debug statements, how can I get the address of the BlueSmirf?
Thank you very much.
Look at the basic Stamp Manual here it tells about the commands.
www.parallax.com/dl/docs/prod/stamps/web-BSM-v2.2.pdf
