A laser etcher for PCB manufacture...?
kjennejohn
This is a C-Net article about two dudes starting a company in·NYC that does custom etching for laptops and such. The thing is, one of them plans to eventually tell how it's done. Could this be applied to board etching for prototypes, maybe even small scale board·manufacturing? Waddayah think?
http://news.com.com/Laser+etching+coming+to+a+laptop+near+you/2100-1041-6143072.html?part=dht&tag=nl.e433
Comments? Suggestions?
Happy holidays,
kenjj
Happy holidays,
kenjj
Technology WILL change the way pcbs are made. There have already been changes and there will be huge changes in the imediate future. Trouble is we just don't know what those changes will be.
Will they be laser, will they be small milling machine, will they be copper printing or some other conductive printing or a wild variation of these. It depends on which technology wins.
As the Romans would say "Let the games begin..."
Kind regards·from Africa,·the continent were we can't even spell tekno.. tecnol.. technology.
John Bond in Kwa Dukuza.
Bean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
Bean.
http://forums.parallax.com/forums/default.aspx?f=7&m=140357&g=140561#m140561
Kind regards from the Africa - Dark Continent
John Bond
Paul
There may be an equally fast yet cheaper and easier way - Read the previous post...
1. Print directly onto your PCB using a cheap dot matrix printer.
2. Then stick your board into the etching fluid and in 20 mins, you have a PCB
3. Then put the etched PCB back in your printer and print the "Screen Print"
4. Drill the board, solder the components and apply power and you have a working circuit. (In my case, it would sometimes be just a puff of smoke!)
It just needs someone in the USA to work with the ink supplier to develop a suitable ink...
Seems to me, we may be missing a very good opportunity here. I would love to be able to build a cheap, high quality and accurate PCB, from schematic to working circuit, in less than three hours, wouldn’t you???
So, if you want to be part of an instant PCB revolution, just develop this system.
Kind Regards from Kwa Dukuza in South Africa, where everything moves slowly…
John Bond
