Address Operator
Carlos Bastos
Hello,
Is there an operator to use as address operator, like "@".
An example:
x var byte
v var word
main:
v = @test
gosub test
end
test:
x = 2 + 62
return
I want that "v" receives the address of the code below test.
It's possible?
Thankz.
An example:
x var byte
v var word
main:
v = @test
gosub test
end
test:
x = 2 + 62
return
It's possible?
Thankz.
·· In PBASIC you can have a DATA statement and retrieve the address of the DATA statement by putting a label in front of it.· Then you can refer to that address by the label.· No @ symbol required.· I hope this helps.· Take care.
I know that with DATA statement I can retrieve de address, but I wanna retrieve the address of portion of code, like
GOSUB Someplace
I need the address of "SomePlace" to save it in Scratch Pad RAM (like in the code fragment at previous post).
If I can do it, then maybe it's possible I use this trick on my code to supply the Stamps technical difficulties.
Thanks again.
"Ah, if you cannot understand my poor write english, our apologies ..."
·· I understand what you’re trying to do.· What I am offering is a work-around.· You can get back to a specific label in a given slot using the technique I described in the other thread (I just realized you have this going in two threads).· I can give you more detail if you like, but the concept is that you will need a variable as kind of a pointer to where you want to go when you get to a specific slot.· The address will be contained within the label name itself in the BRANCH instruction.
