Opto-isolation questions
Greetings friends and neighbors!
This will be my first direct experiance using opto-isolation, so I have a few questions.
First, if I use an ULN2803 darlington array to control a load, is it even necessary to optically isolate the Stamp? Does the ULN need protection in this manner?
Second, say I wanted to control some Solid State Relays directly from Stamp pins, what type of opto-isolator would be the best choice for this applicaton? Does the source current for the isolator come from the Stamp input or an external source?
I appreciate any advice!
Roger
Roger Pierson
Senior Electronics Technicain
DTI Assoicates
Roger
Roger Pierson
DTI Assoicates
First, no. If the load needs isolation, then use an opto-isolator instead of the ULN2803. There's usually no reason to do this.
Second, definitely no. An SSR is an opto-isolator.
Randy
Roger Pierson
DTI Assoicates
Take a look at this thread wherein you will see that I had the almost identical thinking. You will also see how that thinking evolved, which might be instructive.
http://forums.parallax.com/showthread.php?p=609026
Merry Christmas!
--Bill
You are what you write.
Roger Pierson
DTI Assoicates
