Servo Motor Controller
Recently I would like to design a robot arm (~human size), however, the hobby servo is not enough to support the total weight, is that possible I can buy some “high torque industry servo” then connect to PSC? (Refer to below photo)
On the other hand, I am curious to know what kind of motor (Servo, DC, air/hydraulic piston etc…[noparse];)[/noparse] for Japanese robot (such as ASIMO) in order to control its arm/joints moment, for my opinion, it is quite similar to industry robot arm, did any robot builder have any idea?
Appreciate if someone can reply. Many Thanks!
There are some higher torque servos sold by CrustCrawler, but these use a non-standard communication protocol that would not work with the Stamps. It could work with the SX or Propeller processors. They sell their own controller, but I believe it's designed to connect to a PC rather than a controller like the Stamp.
I just found some powerful “12~24V Gear DC motor” (torque definitely higher than hobby servo), so that I may use this to instead the servo in order to control my robot arm. However, as I look through parallax product such as motor mind, HB-25, PWMPAL etc, there are only able to control max two DC motors in the same time, but my project need at least 16-axis (mean 16 motors), so is that possible I can buy 16 motor mind and link all together to one basic stamp BOE?
Or else do some of you have better suggestion? ·Servo amplifier etc, I really lack of knowledge in motion control field….
My problem:· Looking for DC/Servo motor controller that able to control my robot arm (min 16 channels).
···················· Weight of·robotic arm: 1kg
···················· Length of robotic arm : 60cm (As fully extend)
Appreciate if you have any good advice.····
kelvin
www.servocity.com/html/servo_power_gearboxes.html
I am still working on my's
·http://forums.parallax.com/showthread.php?p=641010
Fernando Gomez
revinc.us
gomez-rivera.com
Never compare yourself with anyone else, there will always be someone bigger·or·smaller·than you.
