PRC 1.02 SOLD OUT! -- here comes Rev 2.00
Revision 1.02 of the PRC is now SOLD OUT. I want to take a moment to thank Mark, Parallax, and most of all, my patrons who made this a success. The profits are being funnelled back to fund Revisions 2.00 which will incorprate suggestions and experiences from its predecessor. It is almost complete and I hope to be submitting the layout for the Rev 2.00 prototype board on Monday 12/11/2006. If it all goes well production boards should be available in early January 2007. Check back here in a week for a progress report.
www.wulfden.org/PRC/
Rev 2.00 has Propeller Plug compatibilty, while retaining USB2SER use. Some hole re-alignment for easier construction. There will be an PRC I/O Daughterborrd which will have two PS2 ports and either a composite video port or a VGA port (builder's choice). Anybody have any more suggestions? Now is the time to speak up!
cheers ... brian riley, n1bq, underhill center, vermont
See the K107 Serial LCD Controller at
www.wulfden.org/k107/
That's great news. I just finished building my PRC 1.02 last night and I thought it was a very well designed board that was easy to assemble. The daughterboards sound like a great idea. In addition to composite video, VGA and (2) PS2 ports, I'd also add an audio output port. As you can see from this link http://forums.parallax.com/showthread.php?p=606294 it would consist of a 200 ohm resistor, and 0.1 uF and 10 uF capacitors plus an RCA phono jack.
The one other change I would make is to add a socket for the crystal to the kit. By leaving the crystal socket empty and the EEPROM socket empty, I was able to use the Propstick USB on the PRC board. The Propstick USB is powered from the regulated 3.3V from the PRC on pins 12 and 32 - same as the P8X32A-D40. You may also want to offer a kit less the Propeller chip, crystal and EEPROM for Propstick USB users.
Forrest
