access to byte array passed to subroutine
I try to read bytes from an array passed to a subroutine
for further processing.
SUB mtI2CwritePage
· mtVARaddress_LSB = __PARAM1
· mtVARaddress_MSB = __PARAM2
· mtVARrdata = __PARAM3
· mtI2C_START
· mtI2C_SEND mtVARi2cid
· mtI2C_SEND mtVARaddress_LSB
· mtI2C_SEND mtVARaddress_MSB
· for mtVARwdata=0 to __PARAM4
··· __PARAM2 = mtVARrdata[noparse][[/noparse]mtVARwdata]·· 'this gives error
··· mtI2C_SEND __PARAM2
· next
· mtI2C_STOP
· return
the sub is called with mtI2CwritePage address,array,count· 'address is word, array is byte, count is byte
array is the address of a byte array.
How to make the subroutine know that array (__PARAM3) is the address of a byte array?
regards peter
SUB mtI2CwritePage
· mtI2C_START
· next
· mtI2C_STOP
· return
regards peter
Arrays are passed by address (byte). So you use the virtual array "__RAM" to access the data in the array.
P.S. You should store your __PARAMx values as soon as possible. Many commands use the as temporary storage (overwriting their value). This can cause problems that are very hard to find.
Bean
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
Post Edited (Bean (Hitt Consulting)) : 12/9/2006 12:19:07 PM GMT
The following compiles,
SUB mtI2CwritePage
· mtI2C_START
··· __PARAM3 = mtVARrdata+mtVARwdata
··· mtI2C_SEND __RAM(__PARAM3)
· next
· mtI2C_STOP
· return
Is this the easiest way when using sx48?
regards peter
Your too fast [noparse];)[/noparse] See my edited post above.
Bean.
Your example showed the for/next must start with 1.
I had 0 and noticed in the list view it then loops one too many.
I try to use as few temporary variables as possible.
It is quite safe to use the higher __PARAMx directly
as long as called functions have only 1 parameter.
Obviously I check that in the list view and if any __PARAMx is used
that my code is using, then I introduce a new temporary variable.
regards peter
mtVAR··var·byte(6)
mtVARwdata·var·mtVAR(0)
mtVARrdata·var·mtVAR(1)
mtVARi2cid·var·mtVAR(2)
mtVARcount·var·mtVAR(3)
mtVARaddressL·var·mtVAR(4)
mtVARaddressH·var·mtVAR(5)
then the subroutine
SUB mtI2CwritePage
· mtVARaddressL = __PARAM1
· mtVARaddressH = __PARAM2
· mtVARcount = __PARAM4
· mtI2C_START
· mtI2C_SEND mtVARaddressL
· mtI2C_SEND mtVARaddressH
· for mtVARwdata=1 to mtVARcount· 'error
· next
· mtI2C_STOP
· return
gives compile error
byte parameter expected "mtVARwdata"
but mtVARwdata is defined as a byte
How to resolve this?
regards peter
