Math Help
TC
OK, I have no idea what size resitor I need for a LM337 adjustable negative voltage regulator.
www.st.com/stonline/products/literature/ds/2167/lm237.pdf
Page 8, Figure 17 is the one I am going to use.· I am looking for -13.6V output.
Please help
TC
We all make mistakes when we are young………That’s why paste is edible!
Please help
TC
If you don't like wrestling with numbers, then rig up the circuit with a 240ohm resistor (from·OUT to ADJ) and a 5Kohm pot (from ADJ to GND.)· When you dial that to your desired voltage, take the pot out circuit and measure it.·
[noparse][[/noparse] You're not going to find a resistor of/with this precise value. ]
** Post Edit **· Well, as you'll see, your Uncle Stamptrol took all of the thinking out of this for you.
Post Edited (PJ Allen) : 12/9/2006 1:54:38 AM GMT
Looking at page 8, fig 17, the output voltage equation is given.
You have to flip back to page 4 to get Iadj from the specs, but it is very low, about 65 uA. In practical terms, it will have little effect on Vout.
Therefore the equation looks like:
Vout= - 1.25(1 + R2/120)
In your case:
-13.6 = -1.25(1 + R2/120)
which simplifies to:
- 1482 = - 1.25 R2
R2 = 1186 ohm
Cheers,
Tom Sisk
http://www.siskconsult.com
Check out this page:
www.interq.or.jp/japan/se-inoue/e_ckt21.htm
It has a dual sided supply using LM337 regulators. This next page:
www.interq.or.jp/japan/se-inoue/e_ckt21_2.htm
...(which can be found by clicking on "Circuit Explanation" on the first page) explains the formula in much better detail than that datasheet.
In addition, there is this page (on a different site):
www.ski.org/rerc/sktf/vol04no2Spring1983.html#national
...which further explains the math.
The thing that is really confusing about the datasheet is the "Iadj" term. Read the other pages and you'll see that it can be completely ignored. According to both of these sites, the formula to directly solve for R2 is:
R2 = 120 * (( Vout/1.25) - 1 )
I added some extra parentheses and an explicit multiplication sign to make sure the formula is understandable.
Thanks, PeterM
Thanks, and have a happy holidays
TC
TC
