improvment suggesstion for basic stamp
After finishing my latest robot and the prototype program, I downloaded the program to the stamp with no trouble.·And as·I was about to disconnect the stamp from the download cable.·I noticed a problem with the code. Then after about 30 minutes·I tried to download it a second time this time it said it could not find the·stamp.
I checked the cable and the power light and both were fine. After trying several more times without success.·then·I smelled something hot·
and·I thought that was weird since·I had nothing on. Except my computer my basic-stamp·and a light. Then I noticed·the basic stamp.·I thought it couldn’t be it because it had nothing connected to it except power and the serial cable. No extra parts or anything that could overload the stamp.·And the power supply was 6Vdc at 500ma, but·I decided to·check·it anyway.·I barley touched it and it gave me a second-degree burn!
Nothing was connected to it and there was nothing wrong with it before.
I don’t know what could have happened to it·
· but·I suggest that parallax install a temperature sensor on new basic stamps. if it gets to hot. lights a small red LED and shuts off the stamp untill it is cool.
once again this is just a suggestion.
please respond if·you have an idea why.
Post Edited (crackticus pots) : 12/10/2006 11:58:14 PM GMT
Nothing was connected to it and there was nothing wrong with it before.I don’t know what could have happened to it·
Remember PIE. Power in watts (P) is equal to the current (I) times the voltage (E). P= IE
Roger Pierson
Senior Electronics Technicain
DTI Assoicates
it is not the walwart that was hot
it was the pic it self (the largest chip actualy on the stamp). the power regulator on the BOE development board was cool to the touch. normaly the PIC is slightly warm, but this was HOT!!!
attached is a picture showing wich chip was hot.
there are a hundred types of people in the world,
but I dont have time to name them all.
Dave
Dave Andreae
Parallax Tech Support·
As you can see it has nothing on it. The wires were from an earlier project and had nothing to do with the stamps over heating.
I·have plugged it back in several times and the same thing happens, it gets hot and won't run.
Roger Pierson
DTI Assoicates
the board it self has nothing wrong with it (other that a loose capacitor and a little dust) nothing is melted or crispied. It looks bad because I do not own a digital camera, so I used a scanner and it turned out pixely. then it went through the jpeg compressor which worsened·it·and·I have high speed dial up high speed and that made it really bad because it compressed it even more.·So it looks bad but it is not. Here is a new photo that shows it better. And no, it was sitting on a Particleboard desk not on·metal.·And if you look closely the jumpers·are connected to nothing. And nothing on the board is shorted. it looks fine but it just heats up and won't run
Reply to tj60647:
The switch is an input selector for the servo jacks. It selects either Vdd or Vin.
But here is a scan any way.
sorry, the photos are in graphics interchange format so they lost·some of there color.
Post Edited (crackticus pots) : 12/11/2006 8:26:22 PM GMT
If so - you have a 7v supply and the switch was set to apply the input to Vdd - thats why you smoked it .. Vdd accepts a regulated 5v supply - whereas Vin accepts 6-40v (on the BS2)
