Replacement for MAX 4411ETP
I would like to build an audio circuit for my PropStick, but it's hard for me to solder MAX 4411ETP in this package. Does anyone know any other IC that can be used with Propeller with existing SPIN code.
Kova
Kova
I'm trying to do the same as you. I've think a TDA2822M should be appropriate. Here's an overview:
A stereo power-amp designed for use in portable cassette players and radios. A 3V supply can be used to drive headphones providing 20mW in 32Ω per channel, and a 9V supply will provide 1W in 8Ω per channel for small loudspeakers.
HTH
Cheers,
Simon
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
