Can anyone explain or duplicate this error
·[noparse][[/noparse]code "test debug"
obj
·· com : "SimpleDebug"
·· pad : "Keyboard"
Var
·· long stack[noparse][[/noparse]9]
·· byte thing
·· byte cog
pub Main
·· cog := (cognew(com.start(115200),@stack)+1)
·· pad.start(27,26)
·· repeat
···· thing := new.key
···· com.putc(thing)
···· waitcnt(25_000+cnt)
···outa[noparse][[/noparse]16]
/code]
This code (done from memory,may not be exactly what I got at home) works,
but when I take out the line outa[noparse][[/noparse]16] I get nothing when I run the program.
This isn't how I intend to use the routine, I actually have it working without the outa in a subroutine instead of main. I am just curious why the loop will not execute without the outa statement doing nothing here, when it seems like it would never get called anyway.
obj
·· pad : "Keyboard"
Var
·· byte thing
·· byte cog
pub Main
·· pad.start(27,26)
·· repeat
/code]
As you rightly say it should never run the outa line. I wonder if the problem is the waitcnt, this is the only command that could go wrong if the time was too short. I wonder if increasing the delay would change anything. Grasping at straws, most confusing.
Graham
Paul Baker
Sorry about the delay(no internet at home).
I will try that when I get home out of curiosity, as I stated before when I put the routine in a sub routine it worked fine.(Then I found the monitor object last night and I had to slap myself for recreating the wheel here).
