Servo headers causing short. Fix? — Parallax Forums
ajelliotajelliot Posts: 2
edited 2006-12-07 18:41 in Robotics
I have a couple of futaba servos with the standard three pin headers. They're causing all kinds of trouble in my bot because when I plug them into their posts, and only when I plug them in, the data and power lines get shorted. The headers are all plastic, so I can't just open them up and rewire them.
Has anybody had this problem before? Is there a fix other than cutting the headers off and hardwiring the pins? I'd like to be able to use these servos in other projects if I have to.
Thanks a lot,
-aje
  • ajelliotajelliot Posts: 2
    edited 2006-12-07 07:47
    Actually, the servos themselves are busted. The data and power lines are somehow fused internally. I must have melted something.
    edited 2006-12-07 17:53
    Hello,
    ·· This can happen if you power them from too high a voltage source.· Servos are typically rated at 4.8V to 6V, though many are powered from up to 7.2V packs.· Anything more and you risk damaging the internal control circuitry.
  • Steve JoblinSteve Joblin Posts: 784
    All is not lost... open up the servos, unsolder the circuit board from the motor, then solder two wires to the motor, and close everythig up.· Now you have a very easy to mount gear box motor that can be controlled via a small motor controller, like the Pololu Dual Serial Motor Controller!
