replacement for the RC1117S33T
Matt Battle
Hey all,
I know this has nothing to do with parallax products but i know there is alot of you electronics folks out there. I am looking for a replacement for the obsolete Fairchild Semiconductor's RC1117S33T-ND which is a Voltage Regulator for 3.3V at 1A in a SOT-223 package. Thanks
Matthew
Post Edited (Matt Battle) : 12/6/2006 10:03:06 PM GMT
Matthew
LM3940IMP-3.3
LX8117A-33CST
Ive only matched those specs you provided, you'll need to check the datasheets to see if any other needed parameters match.
Paul Baker
Thanks for your help. It looks like the LX8117A-33CST-ND is going to be the one I will be using in place of the RC1117S33T-ND. The other two parts have come up as obsolete.
Matthew
I know that voltage regulators run hot but is there anything I can do to cool down a SOT-223 package regulator? Does anybody recommend something else that is more efficient then that? I was told to look into switching regulators. Would that be a beneficial and cost effective switch ?
Thanks everybody,
Matt
Paul Baker
Thanks Paul for the input. Room is limited on the board that I am using so I am stuck with the SOT-223 package I am using. I will be designing a new board the next few weeks and I will be using a voltage regulator in a TO-220 with a heat sink to help distribute the heat.
