Homework Power Up Problem
I have been working to learn to code the Parallal Emic speek board running it on a HomeWork board. I had the demo program Emiv_TTS.BS2 loaded and running OK. I started to "cut and paste" various parts of the program to learn how to program the Emic. Some how I got a command "END" added·at the start of the program. Now when you power up·the HomeWork board the power light on the board comes on for a few seconds, then goes off. Therefore I can not load a corrected program. I have tried new 9V batteries on the board, but this does correct the problem. How can get the bad program that is loaded on the Basic Stamp off if I can not get the power to stay on?
······ Joe Fishback
-Robots are my friends-
······ Joe Fishback
· Try disconnecting everything from the power and I/O lines and try your download again.· Perhaps something in the circuit is causing a problem.
