Any joystick control experts?
I need to learn about controlling some motors with joysticks. Ihave no knowledge about servos, but maybe that is an option for one of the systems. The project would require some of the motors to run continuously, with the postition of the joystick determining the speed. Other parts other system would require a fixed position, so that the position of the joystick sends the motor to a fixed position.
I can imagine a way to do either methods with a stepper, but am thinking that the stepper is not the best suited to the job. There are dumb DC motors that are doing similar tasks, with limit switches to stop the motors if needed. The first task is to find a joystick, my guess is that pots on the joystick are how it would usually be done to get positioning. Googling hasn't turned up good info yet. Anyy suggestioned would be great on where to start.
Some ideas:
Servos would be used for a range of motion.
PWM can be use for a straight DC motor for speed variability.
Servos - just depends on stoping at a particular cycle or positioning.· E.g. spin 5 cycles and stop at 180 degrees.
There are several Joystick types. What I would call Digital (uses switches)·or Analog·(uses pots).
On a digital type (Atari), you could have the PWM increase/decrease the Duty cycle holding the stick up/down.
Analog (PC), you could read the pot value and increase the PWM duty cycle that way as well.
There's tons of joystick schmatics on the web. Try http://www.discovercircuits.com/J/joysticks.htm
Just kinda depends on the type of action you're looking for on the joystick, and what overall function you're wanting to provide.
Lettuce know!
Post Edited (Yendor) : 12/5/2006 5:57:31 AM GMT
kelvin
xinchang.en.alibaba.com/product/0/50217117/Potentiometer__Encoder____Switch.html
www.happcontrols.com/joysticks/joysticks_amusement.htm
Post Edited (originator) : 12/5/2006 9:09:15 AM GMT
Paul Baker
