Precise Event Timing Apporaches
Hi
I am working on a physics demonstration and need to start and stop a timing device. Accuracy of 10 millisecond or better would be nice.
I tried using a do loop with with different pulsout values to slow the loop down so that 500 loops would equal a second and then use the loop counter as a "millisecond" counter - but there has to be a better way. The entire experiment apparatus and the code are ready to go but it would be so much better with a real clock timing the events.
I thought the DS 1302 might work but I am not skillful enough to either see if the chip would work or make a simple program to count milliseconds, seconds and leave all the longer intervals out of the code.
Any advice would be appreciated.
Our experiment is dropping a marble and measuring how long it takes to fall different distances. The trigger for the clock start is a microswitch on the end of a solenoid. The solenoid is activated by a pushbutton, the marble sits on top of the solenoid rod, the rod is retracted, the marble starts its fall and the end of the solenoid rod makes momentary contact with the microswitch. This event triggers the clock start. When the marble falls for a meter or whatever length is chosen, it breaks a light beam shining at a photoresistor. This event tells the clock to stop. Everything seems to work except it just doesnt seem right to play around with the timing until the "loop clock" gives the calculated value. We need a real clock.
············· VCC=5V
··············· |·| R
dischargePin· o--+
················ = C
················ - 0V
The C will discharge to some minimal voltage Um when dischargePin is made a low output.
The C will charge via R·when dischargePin is made an input. The threshold voltage is 1.4V
The time T for charging C from Um to 1.4V is given by
T = R*C*ln((VCC-Um)/(VCC-1.4))
Um=0.0V then T = 0.328504*R*C
Um=0.1V then T = 0.308301*R*C
Um=0.2V then T = 0.287682*R*C
basically T = k*R*C
example program
loopcount var word 'number of loops
chargecount var word 'number of charges
low dischargePin 'discharge C
waitforstart:
· if clockinPin=1 then waitforstart
· input dischargePin
L0:
· if dischargePin = 0 then L1
· low dischargePin
· chargecount = chargecount+1
L1:
· loopcount = loopcount+1
· if clockinPin = 0 then L0
'at this point clock is stopped
'time passed is chargecount*T
There is of course some inaccuracy.
The looptime must be significantly shorter than T
for example looptime is T/100
The quotient chargecount/loopcount is a measure for the inaccuracy.
The trick is to find a T that is suitable that will give a large
enough loopcount to keep the inaccuracy low.
Once you have an R and C that gives a large enough loopcount,
you can calibrate for k (which will differ from the calculated k)
regards peter
by just counting
waitforstart:
L0:
'time passed is loopcount*T
where T is the time for a single pass through the loop.
To calibrate:
apply a low going pulse to clockinPin which has a known
low period time and note the loopcount.
The looptime T then equals lowperiod/loopcount
You can generate an accurate pulse with a 2nd stamp.
regards peter
I am an electronics rookie and learned a lot by reading your RC post and playing around with some different values.
Actually, I am approaching the problem in a different way now. I really wanted to do the timing without using the stamp so I took apart an electronic stop watch and soldered some leads on the start, stop, reset buttons. Essentially, all I have to do is momentarily connect these leads to start and stop. Even this is causing me some problems though. All I want the Stamp to do is to send a signal to a "switch" that will start or stop the clock. I need an electronic switch, not a mechanical relay. Since the clock has its own power supply, I need to have it electrically isolated from the Stamp.
My first thought was a transistor but my application seems turned around from my understanding of transistors. I want to switch relatively low power to the clock using relatively high power from the Stamp Out Pin. Do you have any experience with a bilateral switch? or any other ideas?
Thanks again for your time.
Ted
I think you're onto something with the electronic stop-watch.
Use the contacts of the microswitch to start the clock, use a phototransistor with your light beam to stop to the clock and then just have a manual push button to reset. There's no real need for the stamp unless you want to drive a more sophisticated display or something like that.
My only suggestion would be to use a light beam and phototransistor instead of the microswitch to start the clock, too. That way, any delay by the action of the circuitry is identical on the start and finish.
Cheers
Tom Sisk
http://www.siskconsult.com
And you COULD go with something like the: http://www.rhombus-tek.com/co-processors.html
The "Simple Multi-Tasking" chip gives you a settable square wave -- set it to 10 mSec, and the BS2 can do the 'hard real-time' you're looking for.· It gives you a buffered recieve-only UART, too.
Post Edited (allanlane5) : 12/8/2006 3:10:10 PM GMT
I am working on designing a "speedtrap" for RC cars, with plans on making a full "dragstrip" timer/light setup down the line
I have found info on making a simple "stopwatch" using a 555 and counter chips.
http://physics.dickinson.edu/~wp_web/wp_activities/Unit25.pdf
if you take that idea and a 16 or 24-bit counter, pipe in a known timed pulse and have the stamp give it a start and stop signal. then all you need to do is have the stamp read out the counter data for elasped time
you may be able to use the BS2s internal count function but I dont know if you can start and stop it with inputs or do you have to wait for the duration set to end.
I haven't purchased a stamp yet so I am not sure how flexable the count function is.
