Design own PCB with Serial Port for Roboitic Project
Hi all.
I am designing my own PCB for my robotic project. I am planing to include a serial port
for future programming. I used the schematic from parallax (attached below).
My question:
1. Is it I have to connect pin 6 and 7 or 2, 6 and 7. I am a bit confuse with the schematic.
2. What·the different between·Vdd and Vin.
3. Pin 24 on the BS2 have to connect to Vin. If i am using 12v power supply Can i
connect it direct to the pin.
Hope somebody will reply.
Thanks.
azmi.
My question:
Thanks.
azmi.
The schematic is in Eagle software and usually a wire without a Dot is not connected.
If it has a Dot at the intersection, it is connected.
Take a look at the schematics in the Basic Stamp Manual to verify that you are getting the right setup.
Vdd is V+, so is Vcc. In this case, regulated V+ at 5 Volts.
Vss is Ground
Since the BasicStamp has an on-board regulator, Vin is for UNregulated DC and Vdd is for regulated +5.
Regarding the 12v, which BasicStamp are you using?
Some will tolerate +12, but create more heat in the on-board regulator. +9 is better. +7.5 is even better. But often all will work.
If you supply Vin with power, Vdd can be used to output a small current of +5 [noparse][[/noparse]maybe 50ma].
If you supply Vdd with properly regulated power, Vin is useless as the on-board regulator is not operating.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
I am using BS2.
··· You said:
·· If you supply Vdd with properly regulated power, Vin is useless as the on-board regulator is not operating.
One more question just to make sure. If i connect 7805 output pin to VDD on BS2·is that mean I can just
ignore Vin?
Thanks again.
But, double check everything for the right voltage at the right places BEFORE you plug in the BS2.
Whenever I build something, I check the Vdd and Vss for all points with actual power on before I populate the board.
Sometimes there is a solder bridge providing power to the wrong place.
Sometimes a reversed capacitor will actually blow up.
And if you use a diode protection scheme [noparse][[/noparse]to discharge large value capacitors] with the 7805, a backwards diode might create a charge pump with +12 volts where you want +5.
These are all things that have happened to me.
Then, I check all the other pins for continuity.
That way, I don't burn up an expensive device by rushing things.
Also, any problems I have later on don't drive me back to doubting my board's construction.
Are you using Eagle PCB?
I am using Express PCB for the layout.
I tried to download eagle PCB zip file but after extract the file I only can use the program but not the component library file. How actually to use the library file to get the component on the board?
Here I attached the PCB layout.(using Express PCB)
